Old 11-09-2007, 05:30 AM
JRSully JRSully is offline
Default Evans NPG Lifetime coolant
Anybody have any experience with this stuff.? Expensive but supposedly very high quality.
71 Porsche 911 Targa
Old 11-09-2007, 06:17 AM
Default Re: Evans NPG Lifetime coolant
My friend has a race shop and sell lots of it. I think it raises the boiling point to 300 degrees plus. You run a 0 pressure rad cap and no water. He and his race buddies love it.
Old 11-09-2007, 06:19 AM
Mr. Chevy's Avatar
Do you have to completely flush the Prestone out of your current system to add this stuff in, or can it be put in with just a regular radiator flush and not hurt anything if a small amount mixes with the Prestone???
Rich
Old 11-09-2007, 06:41 AM
I dunno..
http://www.evanscooling.com/
Old 11-09-2007, 06:47 AM
You have to get almost all the water out of the system and check it with a Hydronomer.? (the battery testing thing)This stuff is supposedly very good for high compression, high temp solid lifter engines (so I am told)
Old 11-09-2007, 07:18 AM
Boiling point is 375 degrees. If there is any remaining water in the system just get it hot and it will boil itself out with the cap off.
Old 11-09-2007, 05:15 PM
68 Vert 68 Vert is offline
It was in my '72 for 10yrs., neat stuff just a pain when you have to drain and refill as you can't use water to top off. Due to this, I just recently switched back to standard antifreeze. For my application driving 2k miles a year to the local cruise-ins, I think it's overkill.
FWIW, It really didn't make any difference in operating temps...even with the A/C on a Fl. summer day.
Mike
