Old 11-07-2007, 10:11 PM
elonblock elonblock is offline
Default 69 Camaro cowl induction switch and throttle arm
Guys,
From a visual standpoint, how close is the reproduction throttle arm and cowl induction switch compared to the GM parts for a 69 BB Camaro. Is it close, way off, or something totally different?
And has anyone had first hand experience with using the reproduction switch and throttle arm?
All comments welcome.
Thanks,javascript:void(0)
Elon
69 COPO Camaro
Old 11-08-2007, 04:46 AM
Default Re: 69 Camaro cowl induction switch and throttle arm
Not sure about all the differences, but the biggest difference I saw (I have one of each) is that the bolt in the bottom is welded in place on the repop, but not on the original.
Hope this helps.
Lynn
Lynn
Old 11-08-2007, 08:19 PM
Unreal Unreal is offline
I used a repop throttle arm, switch and spring clip. It was a tight fit, and when I tried to force it the switch exploded. I filed the hole a little bigger, and everything went together fine. (D&R replaced the switch for me) I don't know which of the pieces was the culprit.
Old 11-10-2007, 04:35 PM
I appreciate the replies.
69 COPO Camaro
