Old 11-07-2007, 05:58 AM
Default VIN & Dates on 1969 Chevelle frame?
Does anyone know if and where the VIN & date it located on the 1969 Chevelle frame??
Old 11-07-2007, 06:09 AM
Default Re: VIN & Dates on 1969 Chevelle frame?
Tommy,
Here you go....located on driver`s side, behind rear tire...almost end of frame.
Dan.
Old 11-07-2007, 06:19 AM
Thanks Dan! No VIN then? You have a PM
Old 11-07-2007, 03:34 PM
3macs1 3macs1 is offline
Tommy . Don't know about 69 but have also seen a few 70 chevelle stamped on the top of the right frame rail right between the last two body mounts. Frame usually has to be out to see it unless it is a real clean car and you have a mirror to look.
Old 11-07-2007, 04:50 PM
I just got my Fremont, Ca. built 69 El Camino frame blasted, and the vin was clearly visable on the top of the left rear frame rail, just above the part number which Dan showed.
69 El Camino
69 Nova
C7 Vette
Old 11-07-2007, 05:13 PM
PeteLeathersac's Avatar
Same gang stamping as Eng/Trans?.
~ Pete
Old 11-07-2007, 08:44 PM
~ Pete
No, totally different. Much bigger numbers.
69 El Camino
69 Nova
C7 Vette
