Old 11-04-2007, 12:42 AM
dang6672 dang6672 is offline
Default decoding protecto plates
Hello, I'm a impala.net member and a newbie here but have enjoyed the site for the last year or so, very entertaining and informative. I bought a 1966 Caprice 2 door last fall and I am getting ready to start a restoration. I would like to confirm a few things, but I am stumped and need some help. The car has the 396/325 with a 4 spd, air, power windows, no power brakes or steering. I bought a "CHEVY BY THE NUMBERS" book and have matched the numbers off the block and the trans. to a 1966 full size car, but when it comes to the protecto plate, I am a lost puppy. Is there any websites to decode the protecto plate numbers? I have seen plenty of Caprice's on the net with the 396 but none with the 4 speed and would just like to confirm what I have is original to the car. Any help would be GREATLY appreciated.
66 CAPRICE L-35 4SPD
Old 11-04-2007, 01:49 AM
TDW TDW is offline
Default Re: decoding protecto plates
http://www.impalass427.com/links.htm
May be something at this site or its links to help.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-04-2007, 05:09 PM
I found a link to the National Impala Assoc. I should be able to find something there. Thanks Tony!
Old 11-07-2007, 08:20 AM
Paul D Paul D is offline
Depending on which plant it came from, if it has an L on the lower couple of lines (options codes) that indicates a wide ratio 4 spd. Some plants didn't put the option codes on the trim tag.
The 1965-66 Full Size Chevrolet club is the source for the code. I believe they also apply to Chevelles.
Paual
PaulD
'64 R-Code Mercury
'62 421 SD Catalina
'66 L72 Impala SS
'66 R-Code Fairlane
Old 11-09-2007, 11:24 AM
mssl72's Avatar
mssl72 mssl72 is offline
If you can post the information found on the plate or PM it to me I can help you.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 11-14-2007, 06:16 AM
mssl72 You have a PM. I've been in S. Dakota pheasant hunting sorry for the slow response.
Paul D. it does have an "L" on the trim tag on the lower portion. Thanks for the response.
Old 11-15-2007, 11:47 AM
mssl72's Avatar
Got it!
Mark
