Old 11-02-2007, 10:30 PM
juliosz's Avatar
juliosz juliosz is offline
Default ZL-1 Tooling Rescued?
Does anyone have the inside scoop on this being true? Is this the original tooling they're talking about?
Wards Article
Old 11-02-2007, 11:00 PM
SSJunkie68-69 SSJunkie68-69 is offline
Default Re: ZL-1 Tooling Rescued?
Can you cut and paste the article? When you hit the link, you have to have a paid subscription to access it.
Old 11-02-2007, 11:06 PM
L78racer L78racer is offline
ZL-1 Big-Block Revived After Tooling Rescued From Scrap Yard
By Tom Murphy
WardsAuto.com, Oct 31, 2007 2:26 PM
LAS VEGAS – Muscle-car enthusiasts have attentive eyes to thank for an all-new iteration of a classic and rare big-block V-8 soon to be available from General Motors Corp.
Beginning in spring, GM will sell for a cool $20,000 a modern interpretation of the highly prized, all-aluminum 427 cu.-in (7.0L) ZL-1 V-8. GM will make only 427, and expects to sell every one within a year.
The Anniversary 427 will be rated at 430 hp and 450 lb.-ft. (610 Nm) of torque, just like the original that bowed in 1969. GM made only 200 of the engines over the next several years.
Sixty-nine of them were used in Camaros and two in a pair of ‘69 Corvettes. Today, those cars trade hands for at least $1 million apiece, says Jamie Meyer, product integration manager for GM Performance Parts, on the sidelines at the Specialty Equipment Market Assn. show here.
After these classic engines were produced, the tooling for the block was put aside, collecting dust for some 30 years, until a sharp-eyed member of the GM Racing team stumbled upon it in a Michigan scrap yard, Meyer tells Ward’s.
“Someone who knew what they were doing was going through the scrap yard, recognized what the ZL-1 tooling looked like – you’ve got to appreciate that – and said, ‘We need to pull this out of the junkyard and see if we can fix it,’” Meyer recalls. “And it’s actually taken us several years and several hundred thousand dollars to refurbish that tooling so we can build 427 of our anniversary engines.”
Every engine will be serial numbered from 1 to 427 and will come with documentation of authenticity, as well as emblems for the car. “They will be very collectible crate engines, regardless of what car you put them in,” Meyer says.
Anniversary 427 will be rated at 430 hp and 450 lb.-ft. (610 Nm) of torque, like original in 1969.
If GM can sell each engine for $20,000, why not sell more than 427?
“Because the tooling actually wears out,” he says.
The engines will be produced in Michigan, but Meyer declines to identify the specific plant.
He doubts GM will develop new, more robust tooling to produce the 427 in higher volumes; such an endeavor would cheapen the premium nature of the special-edition mills. “But we may make the block available for quite some time, so someone can build their own,” he says.
The engine will be available for sale through the GM customer Web site and GM Performance Parts dealers.
Meyer expects the engines to be used primarily in remanufactured ‘69 Camaros. “People may want to relive what they missed in 1969 and build a ‘69 Camaro that has a ZL-1 powertrain.
Here at the SEMA show, the engine is on display under the hood of Project X, a fabulously restored ‘57 Chevy owned by Popular Hot Rodding magazine. The car played a supporting role in the 1980 comedy, “Hollywood Knights.”
Whatever car gets the 427 Anniversary mill will need a reinforced suspension as well as “a big transmission, a big clutch and a good rear end,” Meyer says.
The engine will come equipped with a 4-barrel carburetor, distributor, oil pan and water pump. Accessories available from GM include air conditioning and a front accessory drive kit.
GM also updated some design features of the engine block, such as the addition of screw-in galley plugs. The casting also was strengthened in key areas.
Based on the enthusiastic response from SEMA gearheads this week, Meyer is convinced the production run of 427 engines will sell quickly. “I don’t think I’ll have 427 engines on my hands for long,” he says. “I don’t think we’ll have them for a year.”
GM developed the original ZL-1 as a lightweight weapon for use in road racing, and the first few were handed out to racing teams supported by Chevrolet. The innovative aluminum block offered a 100-lb. (45 kg) weight savings over the conventional iron big-block casting.
In addition to the 427 ZL-1, the GM pavilion here is packed with high-powered specialty products, including some for the environmentally minded. Many of GM’s 28 vehicles here run on alternative fuels, including E85 ethanol.
Among the crowd favorites is Jay Leno’s E85-capable 600-hp Z06-inspired C6RS Corvette, as well as 500-hp FlexFuel Chevy Hot Rod, inspired by a ‘34 Chevy coupe.
Old 11-02-2007, 11:19 PM
thanks
Old 11-02-2007, 11:25 PM
If this is indeed true, I wonder what this will do to the
value of ZL-1 blocks as seen on PeePay. Thanks to a member
here for that funny take on eBay's name
Wouldn't it be nice to see this tooling in person.
I wonder if you could buy just the block ( fully machined ). Also,
will the casting number be the same as the original?
Nuch
Old 11-02-2007, 11:27 PM
Another thought:
I wonder if GM is doing this to add some additional thump to
the proposed concept Camaro. You know - ties to the past
Nuch
Old 11-02-2007, 11:31 PM
427 engines @ $20K each = $8.54M. That's Lillard type money
Not a bad return on the "several hundred thousand dollars " that went back into refurbishing the tooling.
Old 11-03-2007, 01:56 AM
ssl78 ssl78 is offline
I thought the Zl-1 blocks was found and retooled about 6 years ago. I have the new ZL-1 block in my 69 Camaro now, if im not mistaking you could only buy the block until now, they havent offered a old school ZL-1 complete motor assy until recently.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-03-2007, 04:45 AM
Fast question for the ZL-1 block experts here. I had been
told numerous times that the original ZL-1 blocks were actually
a bad block design ( weak bulkheads ) and that these blocks
actually weeped oil right through the castings. Is there
any validity to this? Some of the members on the NCRS.org
site actually raced these engines back in the day and the
general feeling I got was that the new ZL-1 blocks were so
superior to the originals, that some members would give an
old ZL-1 block away in order to get one of the new ones.
Steve
Old 11-03-2007, 04:53 AM
Rediculous. The new blocks are way better. But give an original away for a new one; a fool and his money are soon parted.
