Old 10-30-2007, 08:48 PM
iluv69s iluv69s is offline
Default Help with garage design!!!!!!! Ready to drywall..
I,m getting ready to drywall my 24 x 40 garage...I have the typical restoration type tools and equipment...mig...plasma cutter...lift...rotisserie..compressor,etc......I' m going to pipe air throughout the garage from the compressor that will be in the attached shed..can i use copper pipe? What else should I NOT forget to install?? Any good ideas?? Pics???..I'd rather learn from others mistakes...or experiences...Thanks in advance..How about flooring material?? I thought about the flake type paint..but with the welding,etc.?? I considered a thin plywood for the walls also..Instead of drywall...easier to attach stuff??
Any ideas would be great...thanks again!!!
Old 10-30-2007, 09:31 PM
427.060 427.060 is offline
Default Re: Help with garage design!!!!!!! Ready to drywall..
Be sure you have plenty of electrical outlets including a couple 220 volt ones. If you think you have enough outlets now, add a few more. I would use steel or PVC pipe for the air lines. Steel would be better in my opinion. Copper is very expensive right now. Plywood is a good idea. Use at least 1/2". Personally I would use 3/4". It's a lot stronger and won't warp between the studs. The plywood will stand up to abuse a lot better that drywall. Insulate the walls and ceiling before installing the plywood or drywall. How high is your ceiling? What tpye of garage door are you using? I like the coiling overhead type doors. They cost a little more but you don't lose the overhead space when the door is open.
James
1968 Beaumont SD396
Old 10-31-2007, 01:39 AM
Never use PVC for shop air lines! The oil in the air will deteriorate the pipe and welded joints causing faiures. Black pipe is excellent with a filter/regulator at the end of every downspout. A single filter/regulator won't catch all the moisture if mounted to close to the compressor as the air is too hot for the filter to be most effiecient.
Howard
Old 10-31-2007, 01:43 AM
Almost forgot... I like to mount my blast cabinet on casters so that it can be used outdoors and then stored inside. Better to leave the mess outside and clean up with a lawn blower than a broom and dust pan.
Howard
Old 10-31-2007, 01:47 AM
Use 5/8 "Firerock" (Fireproof Sheetrock) and where needed install pegboard for hanging whatever.........
Chuck Sharin
[email protected]
70 Camaro R/S Z-28, L-78
69 Camaro COPO recreation
Old 10-31-2007, 03:07 AM
kwhizz kwhizz is offline
There are Aluminum Air Lines systems made specifically for Compressed Air Applications , Cut and Push fit fittings, elbows etc.....Only way to go, Flows more air than steel and "No" Rust issues.....When we did our New Building that's what we used (along with a Screw Compressor and a Chiller Dryer)......"All" the Air related issues are a thing of the past.....Don't remember the name of the system right now, I'll find out and Post later
Ken
Old 10-31-2007, 03:09 AM
First thing I would do if I were you is determine how many vehicles you want to park inside the garage when it is all finished! Then design your layout around that.If you are going to do a lot of work in the garage I would also look at a plywood wall covering or siding instead of sheetrock.Personally I am going to use a 4x8 plywood that looks like bead board,my Garage doubles as a game room also and has central A/C and heat.Just a few tips from my experience!
#1.You can get some garage design books that have some really cool ideas and pictures.
#2. Determine how many vehicles you are going to park in the garage and design around that.
#3. Install more than needed electrical outlets and be sure to add a few 220 volt outlets in areas you may use welder or other 220 volt tools etc!
#4.At this point you can install all the piping for the air lines in the wall,I would use galvanized pipe to help cut down on rust from moisture in the piping and install a good filter system and install outlets in strategic areas throughout the garage and maybe even one outside to blow off the mower after use!Do not use PVC or CPVC for airlines!
#5.Insulate well now! You will be glad you did in the future!
#6. Use a good water barrier but be sure to let the garage breathe,install a couple of good vents and if you think you may install A/C use vents you can open and close at your discretion.
#7.Decide on good solid cabinets,Sears makes some really nice ones,they are a little pricey but look great and are durable.
#8.Use good quality durable paint on walls and ceilings Personally i would use a good epoxy paint! and pick a good durable floor coating.Members here have used different types and they can recommend some good ones.
#9. You can also install a fire suspression system in the garage that will automatically discharge in case of a fire.They cost a little bit but not near as much as you will have in the garage and what you keep in there! A very good piece of mind!Or install good fire extinguishers in startegic areas.Or Both!
#10. Just be thoughtful and try to think ahead to minimize mistakes on installing air line outlets,electrical outlets,vents etc. Storage of items you are going to keep in the garage.
#11. The value of your home also depends on the quality of your garage and If you decide to sell later on it makes a good selling point to the MAN OF THE HOUSE! Especially if he is a CAR GUY ALSO!And maybe the LADY of the house also.
#12. You started off right about asking others questions,now get a couple of books and look at some picture of garages and make a few decisions and GET TO WORK! LOL The better you plan now will make it a lot easier down the road!Don't scrimp on the garage funds you will regret it,you can be frugal and have a fantastic garage too!
Legris is the name ........Here's a Link.....
http://www.garage-pak.com/faqs.html
Ken
Old 10-31-2007, 03:30 AM
TDW TDW is offline
www.garagejournal.com has some neat stuff.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
