Old 10-19-2007, 09:23 PM
dlv4540 dlv4540 is offline
Default 1969 427 Copo, Yenko factory replacment engine
427 4 bolt block all cleaned, magged and honed to 60 over ready to drop the pistons in. The block has new freeze plugs and cam bearings installed and has the CE9XXXXX on the front pad. The block will come with new dome closed chamber pistons with new rings mounted on GM 7/16 dimple rods, new double roller timing chain, new L88 replacement comparable camshaft and lifters, standard #7115 steel crankshaft, 3964291 square port heads dated F-4-9 and F-6-9, 8 inch harmonic balancer, 8 inch timing cover, oil pan and new chrome valve covers and hardware. $6,000 firm 330-770-2517
Dennis Vugrinovich
Old 10-21-2007, 01:20 AM
TXSS TXSS is offline
Default Re: 1969 427 Copo, Yenko factory replacment engine
Dennis
What is the casting number and date code on the block?
Rick
Old 10-21-2007, 11:40 AM
Casting number on the block is 3963512 and it is dated H-20-9 which is August 20th 1969.
Dennis Vugrinovich
