Old 10-16-2007, 08:11 PM
Default 1968 z-28??
I'm going to look at a 68 z this weekend. No paper work. Not orginal motor. Early car Nov. has 302 emb on front fenders. 12 bolt 373 gears. orginal 4-speed. power disk. What else should I look at to decide it's one??
Jake is my grandson!!
Old 10-16-2007, 08:35 PM
ssl78 ssl78 is offline
Default Re: 1968 z-28??
Single fuel line, it should have 4 piston disc brakes, tire inflation sticker in glove compartment that says 15x6 wheels, High redline tach.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 10-16-2007, 09:04 PM
Stefano Stefano is offline
DF Coded 15" Rallys would be a good Clue, 4 Leaf Springs, Hi-Red line Tach is Z28 or L78.
Old 10-16-2007, 09:56 PM
All 68 Camaros had a single fuel line. Two fuel lines started in 69.
Doesn't necessarily have a tach, that was an option.
Martin Foltz
68 Camaro SS-396
Old 10-16-2007, 10:25 PM
firez firez is offline
Fast ratio steering box plus fast ratio steering arms.Not sure of part #s. A lot of early Zs had the brake proportioning block mounted on the drivers side frame rail.This only came on disc brake cars.
1968 LOS Rallye Green Z28
Old 10-16-2007, 10:55 PM
It has the high rpm tach. I will check the glove box. Thanks Guys
Old 10-17-2007, 12:15 AM
Are you sure about that? I used to own a 1968 SS/RS 396 that had the finned drums up front and it had the block on the driver's side frame rail.
Old 10-17-2007, 12:37 AM
What is this car worth?? Very nice correct car.
Old 10-17-2007, 12:40 AM
The car is silver with black stripes.
Old 10-17-2007, 08:10 AM
JChlupsa JChlupsa is offline
My 68 RS 327 with drum brakes also has it
