Old 10-10-2007, 08:57 PM
chads454Ls6 chads454Ls6 is offline
Default 1970 ls6 chevelle
Not mine and do not know the owner.
Gotta love a sept cast block in an 03b car!
http://cgi.ebay.com/ebaymotors/1970-LS6-...1QQcmdZViewItem
Old 10-10-2007, 09:07 PM
427king 427king is offline
Yenko Paid Member
Default Re: 1970 ls6 chevelle
[/ QUOTE ] So you are saying it couldnt happen
Old 10-10-2007, 10:06 PM
Rainer Rainer is offline
Regardless of whether the date is correct or not on this car, showqualityone (the ebay seller) is suspected of building bogus cars. His ebay buying history included LS6 blocks, heads, blank trim tags, and an engine stamping set. Check out this post from Team Chevelle and then tell me if you'd trust anything from this guy...
http://www.chevelles.com/forums/showthread.php?t=156818
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 10-10-2007, 10:08 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Are those SS emblems upside down??
Old 10-10-2007, 10:19 PM
Absolutely upside-down...
Old 10-10-2007, 10:38 PM
mockingbird812's Avatar
Back to the block cast so far prior to car build: It was not uncommon to see this occur up to 6 months of a delta (betw casting of block and build of car) acoording to Jeff Dotterer. He said this was primarily due to relatively low production numbers for the LS6 cars. They would cast a bunch of blocks based on projections and dole them out as the RPO was checked off by the customer.
I am making NO statement about this particular car in this thread.
Sam...
Old 10-10-2007, 10:42 PM
PPPJJJFFF PPPJJJFFF is offline
I never really thought of the LS6 cars as "low production" cars.
Patrick
Old 10-10-2007, 10:50 PM
That is why I used the word "relatively". The bean counters at GM have to make projections on how many they feel the public will buy so the supply/support folks can ramp up to meet these needs. If they overestimate (which may have been the case with the 70 LS6) you will more likely see longer periods between casting dates of unique items (i.e. LS6 block) and the build date of the car.
Sam...
Old 10-10-2007, 11:19 PM
Late BrakeU2 Late BrakeU2 is offline
Patrick
Considering they built nearly half a million 70's I think the term is quite accurate-perhaps not if you own an L89,but they did build 51thousand L34 SS's.All depends on your frame of reference
Old 10-11-2007, 12:11 AM
Patrick
O.K. I can look at it that way!
Patrick
