Old 10-07-2007, 02:35 AM
169yenko 169yenko is offline
Default 1969 Camaro Grille Refinish Tips
I have seen a few things on this in the forum already, but not on my specific question. Were the silver grilles painted silver basically only from the front and the back was black or ? I have a very nice original grille someone painted black and I would like to refinish in silver. Also, any spray can brands or part # recommendations to accomplish a good job? Any prep and spraying tips? I.E. spray the back with color 1 and then do the front? Thanks.
Tim
Old 10-07-2007, 02:54 AM
Default Re: 1969 Camaro Grille Refinish Tips
The back of the grill was an off white "bone" color, not black. I beleive they were painted silver from the front with some overspray going to the backside.
jason
Old 10-07-2007, 03:15 AM
m22mike's Avatar
m22mike m22mike is offline
Replacement parts grills were black, probably more of them floating around than the OE ones now.
Mike A
Old 10-08-2007, 03:08 AM
GaryB GaryB is offline
I believe the original grilles were actually molded with silver plastic not painted silver. I may be wrong but that's what I think.
67,68, & 69 Z/28 Camaros
Old 10-08-2007, 04:51 AM
KevinW KevinW is offline
Silver grills were molded in a gray or off-white color and painted silver over the entire front with a LOT of overspray on the top. Then the center section was masked off and the body color was painted over the silver. The mask was not very precise and you could see some of the silver outside of the stainless strips.
http://www.camaros.net/forums/showthread.php?t=116646
69 327 convertible (driver)
Old 10-11-2007, 05:45 AM
Unreal Unreal is offline
If you have an original silver grille that someone painted black, it will have the gray/white mounting tabs. If it does, I'd consider removing the paint and then repainting argent silver. I'm told silver over black looks totally different than silver over gray. I've never compared them side by side, though.
Old 10-11-2007, 06:05 AM
Here are a few from my 69 original grill. They may help.
