Old 10-01-2007, 04:46 AM
firez firez is offline
Default 678 CE block
Anyone know how this breaks down date I67 Pad CE8 26649. Now the 49 on the pad seems to be stamped alot deeper. Is this normal with a warranty block or no? Thanks
1968 LOS Rallye Green Z28
Old 10-01-2007, 05:09 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Default Re: 678 CE block
I have two CE blocks in the garage, both from the same month and year as what you are looking at (although mine are 657 blocks). The last two numbers on both of mine are clearly stamped at a different time than the others. The alignment is off and the depth of the stamping is different.
-Jon
Old 10-01-2007, 05:17 AM
Sounds typical:
I=Month September.
6=Day,6th.
7=Year cast,1967.
C=Chevrolet
E=Engine
8=Digit for the model Year put into service,1968.
26649th unit produced for service at Flint facility.
Old 10-01-2007, 05:21 AM
Would these be used in LA cars also?
Old 10-01-2007, 05:26 AM
Yes,as it's not an assembly line engine.
It's a replacement/warranty block,issued/sold by any GM dealership in the country back then over their parts counter.
Old 10-12-2007, 06:04 AM
Does a CE block usually have a cast date after the build date of a car or could the CE block be any date earlier or later than the build date of a car?So long as it is cast for that year of car.
Old 10-12-2007, 07:29 AM
427.060 427.060 is offline
Typically, it would be later that the build date of the car. It the engine were replaced early in the cars history it could be dated earlier than the car.
James
1968 Beaumont SD396
