Old 09-30-2007, 09:38 AM
Default 4X4 wheel help
The Donahue volunteer fire dept has been awarded partial funding from fema to puchase a new brush/rescue truck. We have spected out a 08 Ford F450. This will allow us to carry 300gal. of water and 15gal of foam, scbas, and limited medical equipment. Our problem is that a 450 comes only with dual rear wheels. In the terrain that we cover, we need a single rear wheel setup. We've been told that no one is yet making a wheel conversion setup for 08 F450s.
This board has a lot of diverse, and knowledgeable folks, so does anyone know where we can go to inquire about this setup?
Thanks in advance, Schonye, DVFD
Old 09-30-2007, 10:34 PM
Chevy454 Chevy454 is offline
Default Re: 4X4 wheel help
Try http://www.superdutydiesel.com/
Also, there's lot of good info over at dieselplace.com
Our gravedigger has a new SD...I'll run it by him and see if it's doable...why isn't it, doable? On the Chevys the rears are the same, I believe, as I see lots of folks around here with duallys simply take off the inner wheels and run the single outer wheels/tires with the offset dually wheel...looks decent, actually?
Old 09-30-2007, 10:54 PM
StriperSS StriperSS is offline
I was dealing with a fellow in Washington State who was trying to spec trucks for first response forest fire fighting, and at the time, the 2000 Chev and GMC were the only ones with a narrow enough track to fit where log skidders had been.
I'll try and dig his info up for you. He had looked at conversions and other options.
You could also look at the outfits that convert trucks to run on railroad tracks, as their track width has to match the rails.
