Old 09-29-2007, 08:41 PM
dlv4540 dlv4540 is offline
Default 1969 427 Copo, Yenko replacement motor
I have a 3963512 block dated H-20-9 with a CE9XXXXX stamped on the front pad. This is a four bolt block freshly done to 60 over with new freeze plugs and cam bearings and is ready to drop the pistons in. I have the 3962491 heads dated F-4-9 and F-6-9 along with the 3933163 aluminum intake and the factory #7115 steel crankshaft (standard). With the block comes a new set of 11.25 to 1 pistons with the rings and mounted on a set of factory 7/16 dimple rods, L88 camshaft replacement in box, 8 inch harmonic balancer, 8 inch timing cover, new double roller timing chain, oil pan, and chrome valve covers with hardware. $7500
330-770-2517
Dennis Vugrinovich
