Old 09-28-2007, 07:22 AM
Default 400 Turbo / 350 Turbo - Shifter Mechanism
Wanted - 400 turbo transmission shifter lever from a column shift car. If available, I will purchase the complete shifter assembly from the rod that attaches to the column down to the frame pivot arm, the rod from the pivot arm to the shifter lever and the transmission side shifter lever.
Apparently a 350 Turbo transmission set up from a column shift car could work as well. Also maybe a Nova or Chevelle could work...not sure.
Pls contact me to discuss.
Thanks
