Old 09-15-2007, 05:57 PM
Wardy Wardy is offline
Default Pinon Angle Question
Quick question:
When setting the pinion angle on a big block camaro with manual trans- you want to allow for the pinion to rise under load to be parallel with the trans output, correct? I read that 3.5-4.5 degress negative angle relative to the driveshaft works. Is this true? How was it set up at the factory?
Thanks
Old 09-15-2007, 08:50 PM
Default Re: Pinon Angle Question
Actually, I meant 3.5-4.5 degrees negative (downward) angle relative to the trans output. Right?
Old 09-16-2007, 03:44 AM
Yes that's about avg. angle
Jake is my grandson!!
Old 09-16-2007, 03:53 AM
camarojoe's Avatar
I recently played with pinion agle in an effort to eliminate a vibration in my deuce. (the '32 not the '70) From what I know, the pinion should aim upwards at an equal amount opposite to the downward angle of the transmission tailshaft. In other words, if your pinion aims 3 degrees up, the trans tailshaft should aim 3 degrees down... as long as the degrees of the 2 angles are equal, it should work. (Worked for me at least!)
Joe Barr
Old 09-16-2007, 04:50 PM
Thanks guys. Gotta get this beast on the road.
Old 09-16-2007, 09:38 PM
budnate's Avatar
budnate budnate is offline
oh Mama...thats allot a rubber..
