Old 09-13-2007, 04:51 AM
Bobg302DZ Bobg302DZ is offline
Default 1968 Z28 starter overheating?
I have had a somewhat chronic problem with my 1968 Z28. Original mo 302 with stock exhaust manifolds. Car always cranks and starts right up cold. Runs great does not overheat. However after a drive of 20 minutes or longer, after shutting it off the starter cranks REAL slow almost like the battery is dyi ng. It will start. After cooling off for an hour it cranks normal again. Could the starter be overheating and could that cause this problem. If yes. Is there a fix. Thanks for listening, Bob
Old 09-13-2007, 04:53 AM
JRSully JRSully is offline
Default Re: 1968 Z28 starter overheating?
Sounds like the solenoid on the starter is tired and heat makes it even worse, get a rebuilt starter,or have somebody rebuild yours and that should fix the problem.
71 Porsche 911 Targa
Old 09-13-2007, 05:42 AM
P.J. P.J. is offline
I second the motion Happened to me.
PJ
Old 09-13-2007, 06:04 AM
firez firez is offline
My 68 Z also had the same troubles for a bit. I had it rebuilt being the original starter for the car and have had no trouble since even with the hot summer.
1968 LOS Rallye Green Z28
Old 09-13-2007, 06:18 AM
allcamaro's Avatar
allcamaro allcamaro is offline
Same problem here on my 69 Z/28 I just finished. The starter looked and checked out fine but after further investagation the guts were not hi tourqe that a z should have. We rebuilt it using the correct guts and its fine now, cold or hot.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 09-13-2007, 04:14 PM
drdave69 drdave69 is offline
I had the same problem once and it ended up being the battery. Not enough amps to turn over a fresh (very good compression) engine when hot.
Dave
1987 Grand National
