Old 09-11-2007, 07:23 AM
NOSLO6 NOSLO6 is offline
Default 1986 Buick Regal, 604 hp, 93 Octane 464 ci BBB
Three year total rebuild.Almost everything on the car is new. Totally rust free, new paint,new interior, new wiring, ford 9" rear end with spool, 3.90 gears,and 35 spline axles. New high performance built turbo 400 trans with 4000 stall converter. 464 BBB with all the best parts. 1000 cfm thermoquad,wildcat ported intake with cold water system, ta stage 1 alum heads, sportsman rods,cryogenically frozen block, upgraded valve install with bowl and chamber work, ta timing cover with adjustable pressure regulator, sre alum oil pan,custom curved distributor, romac sfi harmonic balancer, sfi flex plate, ta/srp conicaldish forged pistons, 10.6 to 1 comp (pump gas), competition cams pro-magnum hydraulic lifters, rollmaster billet timing chain set, 5/16 h.d. .080 wall chrome moly pushrods, ta 1.60 rokker rockers, block half filled with hard block, custom grind hydraulic camshaft for this application. Engine made 604 hp and 609 torque. Last time out at Commerce, it ran 10.91 @123.6. It is a very fast street car and has all the NHRA safety equipment to make it legal. Its 3600 lbs with driver .New items recently installed includes. New steel hood w/Postons Stage II scoop,new hood struts,GM roofrail weatherstrip,GM door weatherstrip,NOS sidemarker lights,NOS turnsignal lights,chrome NOS turn signal lever,new sunvisors,etc,etc. I have only touched on some of the big items-there are many small details and some one of a kind items. is a one of a kind BBB Regal. I'm located in the Chicagoland area. Asking $21,500.00 or best offer. Thanks, Dave .630-640-0672
Short Video----https://www.youtube.com/watch?v=SguPjve7Yds
Attachments - The Supercar Registry 332991-1986RegalwithConvos006.jpg 288606-Current1986Stage1464ci002.jpg
