Old 09-07-2007, 01:31 AM
RAREZ11 RAREZ11 is offline
Default 1968 427 4 Bolt Block, 7115 Crank, Dimple Rods
For sale, one standard bore 427 factory 4 bolt main block. Casting number 3935439. Dated D-11-8. True 7115 427 steel crank, and a set of 8 full floating dimple rods. Block will need one or maybe two head bolt threads repaired. Engine was pulled do to spun rod bearing. Crank will need turned or repair the journal. I can E-mail pictures if anyone is interested. No charge to crate and deliver to shipper. $1600.00 plus shipping for all, or I can seperate. I can throw in a 1968 dated flywheel, newer 11 inch clutch and pressure plate. 818-352-2099 Thanks SYC
