Old 08-29-2007, 04:49 AM
69L72RS 69L72RS is offline
Default Cleanup Time
I'm cleaning off shome shelves to make room in the shop.
I will be listing more stuff as more shelves get moved.
Prices aren't carved in stone if you want to make an offer.
I will donate part of the cleanup sale to the SYC .
Aftermarket 12-bolt parts:
1. Eaton HD 12-bolt posi unit, 4-series/33-spline/solid clutches/400# springs NIB $350+shp
2. 12-bolt Schieffer 6.14 PRO gear NIB $150+shp.
3. 12-bolt Richmond 6.14 8620 used $50+shp
4. 12-bolt Richmond 5.38 used $50+shp
5. 12-bolt Richmond 4.56 used $50+shp
OEM 12-bolt 4-series parts:
1. GM 12-bolt posi unit, 4-series/30-spline/10T-18T gears/solid clutches/200# springs tight EC $250+shp
2. GM 12-bolt posi unit, 4-series/30-spline/10T-17T gears/solid clutches/400# springs tight EC $275+shp.
3. GM 12-bolt #3916234 posi unit, June dated OEM blueprint, trade for April dated unit.
4. 12-bolt 4.10 used standard gears $150+shp
5. 12-bolt 4.10 used #3917971 gears (trade only for different dated set) (COPO HD gears)
6. 12-bolt 4.56 used standard gears $25+shp
7. 12-bolt 4.56 NOS #3961410 $350+shp (Standard gears)
8. 12-bolt 4.56 #3917973 used $500+shp (COPO HD gears)
9. 12-bolt 4.56 NOS #3917973 $750+shp (COPO HD gears)
10. 12-bolt 4.88 used standard gears $30+shp
11. 12-bolt 4.88 #3961192 HI IMPACT used $150+shp
12. 12-bolt 4.88 #3917972 used $500+shp (HD gears)
13. 12-bolt 4.88 NOS #3917972 $750+shp (HD gears)
14. 12-bolt 5.13 #3961422 used standard gears $75+shp
15. 12-bolt 5.13 #3961195 HI IMPACT used $100+ship
OEM 12-bolt 3-series parts: (next shelf)
Muncie Parts (4rd shelf)
Corvette parts:
1. NOS L-88 HD differential service kit #3982240 10T-17T Ni gears/22clutches/400# springs and plates. Will include (2) NOS axle seals, (2) NOS axle brgs, (1) NOS #3924031 pinion seal, (1) NOS #3954483 crush sleeve, and (1) NOS stub axle. $1000+shp.
2. RRD case w/ cover ~76 date $100+ship
3. 3-series posi unit (case has no cracks) $300+shp
4. 3.08 r&p set $50+shp
5. yoke $50+shp
OLDS 12-bolt parts:
1. 31-spline posi unit $100
2. NOS 4.66 r&p set $250+shp
Selling for a friend:12-bolt rear removed from 1970 Nova: 4.56/spacer/3-series posi/341NF casting. It has Moroso perches in stock location. Housing has been straightened and axles move freely. $750+shp.
Contact me at:
[email protected]
[email protected]
Eric
