Old 07-25-2007, 08:27 PM
396L78canuck 396L78canuck is offline
Default 1970 L78 & LS6 fuel line
The repop fuel line for my 1970 L78 does not have a hump in the fuel line section from the T brass fitting to the rear fuel bowel making the installation of the pvc line extremely difficult.I thought I have seen a hump in that section on original cars.Am I correct? And who manufactures
a repop with that hump? Thanks Bob
Old 07-25-2007, 09:09 PM
k92 k92 is offline
Default Re: 1970 L78 & LS6 fuel line
I had the same problem on my repop, got one from D and R and it fits nicely.
Old 07-25-2007, 09:21 PM
ORIGLS6 ORIGLS6 is offline
This one?
Also available through Ground Up.
[image][/image]
Old 07-26-2007, 12:44 AM
Denis thanks for the feedback.Is this an original line or a repop?The picture that Rick Peters posted in december 06 in the technical /restoration section on the same subject shoulded a hump at the very spot in the line to allow easier passage of the pvc line.Which one is the correct one
Old 07-26-2007, 06:45 AM
Repro lines with my original fuel block and bracket. I probably cut up the originals when I was swapping carbs and jets back in the hey days.
