Old 07-10-2007, 04:19 PM
DarrenX33's Avatar
Default Sun tach bracket for column mount
This is what I have. It is an 802 tach and I need whatever the heck else it is for me to mount this to my column..
1969 Z28
1972 Corvette
Old 07-10-2007, 06:05 PM
budnate's Avatar
budnate budnate is offline
Default Re: Sun tach bracket for column mount
http://wickedstageact2.typepad.com/life_...tape%5B3%5D.jpg
Old 07-10-2007, 08:17 PM
DarrenX33's Avatar
Ok wiseguy. I'll one up ya and stick it down with pre-chewed bubblegum.
1969 Z28
1972 Corvette
Old 07-10-2007, 09:21 PM
Darren,
I cannot find a picture of it but it seems to me it was a bracket that was cupped on the top to fit the contour of the back of the tach housing and the other end was concave to fit to contour of the steering column. I kind of remember it being held on by one large nut in the center using the large hole you see on the back of the housing and was also chromed. This bracket was in turn held onto the steering column with a very large hose clamp. I see photos of these all the time but cannot seem to find one for you right now. Apologies if my memory is wrong.
Old 07-10-2007, 09:44 PM
@wot @wot is offline
That is exactly what the bracket looks like. Black in color and concave to sit on top of a curved surface. The dashboard one is the same except it has two flat spots on base and only a slight curve between them. Should be fairly easy to locate.
Dean
Old 07-10-2007, 09:57 PM
Rixls6 Rixls6 is offline
Here's a picture of what I believe is the correct one.
Rick
Don't text and drive.
Old 07-10-2007, 10:24 PM
Bingo. The bracket I had mounted on my Chevelle was chrome as I recall.
Old 07-10-2007, 10:27 PM
DarrenX33's Avatar
I'll take it!
1969 Z28
1972 Corvette
