Old 07-05-2007, 06:30 AM
ss427copo's Avatar
ss427copo ss427copo is offline
Default 67 SS427 Impala R/Spring Advise?
Just getting around to figuring-out the 3/4" ride height difference from the lower, driver side vs.the higher passenger side (both at the front & rear, even though the front is a tad bit less), measured from ground to mid-line of wheel opening) on my Impala.
Frame has never been off, front end rebuilt in 84 yet rides like a dream. Has F41 suspension. Thought about doing the rear springs to see what that does?? Any advise on this step and maybe where to buy the springs that would be correct .
Jeff x2
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 07-05-2007, 07:57 AM
StriperSS StriperSS is offline
Default Re: 67 SS427 Impala R/Spring Advise?
Is your car nice enough underneath to still be able to read the tags on each spring? It's possible that at sometime in it's life, one spring may have been replaced.
If you can read the little tags, and post the letter codes, I can tell you what springs they are.
John
