Old 07-05-2007, 05:18 AM
P.J. P.J. is offline
Default 3916323 block
My Car and parts catalog states that the 323 block is used on 68 chevelle, camaro,Nova. and passenger cars.
So If that is the case, then Is this enjine
1967 396/375 hp L78 motor 323 standard MQ block, 840 heads, 6223 steel crank,
Block - 323
T0630MQ 7N252510, E-18-7
Heads - 840
E-18-7 (both)
Is May 18 1967 too early for a 1968 car???
Did GM use the 323 block on Chevelles in 1967
PJ
Old 07-05-2007, 06:49 AM
427king 427king is offline
Yenko Paid Member
Default Re: 3916323 block
yes,#323 block was used in late 67 production.
Old 07-06-2007, 03:17 AM
Steve Shauger's Avatar
Administrator
Block - 323
Heads - 840
E-18-7 (both)
PJ
I have owned two 67 L78's one in a camaro and one in a chevelle. Both were late production chevelle 7c engine 7/3 assembly and the camaro built 7b with a 6/30 assembly date(my car was 88 cars later). Both were cast E 8 7 and I know of several others 323 MQ coded engines with E 8 7 casting dates.
www.vintagecertification.com
Old 07-07-2007, 06:08 AM
Thanks for the info
PJ
