Old 07-03-2007, 04:59 PM
golfer golfer is offline
Default 1964 Mercury Comet Build sheet K code Super Nice
1964 Mercury Comet Caliente K code build sheet $50,000 in receipts. Nicest car on the market for $20,000 for pics [email protected] or for more info call gary or kevin 770-956-1227
Old 07-03-2007, 06:45 PM
1970Bluel78 1970Bluel78 is offline
Default Re: 1964 Mercury Comet Build sheet K code Super Ni
I may be wrong ( looking into it ) but the " K " code designation for the Comets is NOT the same as a Fairlane. I think 225 HP was all you could get in the Mercury in 64. No 271 HP cars. Curious what the build sheet shows? Many people see a K and think HiPO but K can designate Kansas City build. Depends where it is in the vin
1970bluel78
Old 07-03-2007, 07:37 PM
Looked at a 64 Comet brochure. Cyclone V8 highest was 210 HP. No mention of a K code. All comets with that V8 I think would be A codes
1970bluel78
Old 07-03-2007, 11:20 PM
The K code surprised me to, but do more research, there were a lot of K code Comets made, same carb as in the mustang but no solid lifters. Horsepower was listed as 220 in the webb site I found.
Old 07-04-2007, 08:41 AM
tom406 tom406 is offline
It's a really odd thing, these '64 Merc Engine codes being different than the Fairlanes that were likely built in the same plants. The K-code for Mercs was a hydraulic lifter 4bbl regular fuel engine, which was basically the same as the D-code engine you'll find in some early '65 Mustangs.
There were HiPo Comets made in '64, notably the 100,000 mile Durability Run cars and the European Rally cars made that year. In the manuals HiPo Comets are shown to have a "D" code, but all of the HiPo cars found with build sheet documentation are "F" and "K" coded cars that were specially converted. No "D"-code HiPo '64 Comets have ever surfaced.
K-code in the Fords were the 271hp solid lifter engines, and they ALWAYS had 4 speeds (until '66 anyway) and 9" rearends.
Another odd K-code fact is that in '65 a few Canadian Falcons were spec'd with K-code HiPo engines. The "Wild Child" A/FX car started out as a factory HiPo Falcon. No American HiPo Falcons have ever surfaced, however.
For those into Ford Small Block history, the definitive book is Bob Mannel's 700 plus page "Mustang and Ford Small Block V8 1962-1969 Vols I and II", (RPM PRESS). It's a phoenomenal document with extensive pictures and a lifetime of collected info. Imagine a Colvin "By The Numbers" book with actual photographs of everything.
Old 07-04-2007, 04:38 PM
There were NO RPO 289/271 cars made for Comets in 1964 . That K for the Merc does not mean the same thing as say a Fairlane as Tom indicated. Not sure what you have to sell but Probably a 289/210 horse Cyclone V8 Comet
1970bluel78
Old 07-04-2007, 04:45 PM
P.S. Golfer. What kind of rear does she have. Tappered axles?? What gearing? Is there any indication of the 289/271 on the build sheet? The 64 Hi-Po Comet is one of those Mystery cars. Under the hood,are the support braces welded or bolted ??
1970bluel78
Old 07-04-2007, 05:02 PM
Like I have already said, a 64 K code Comet is not the same as a K code mustang. They are still fairly unique, and it apparently has the same hipo carb as the k code mustang. HP rating I found was 220, another place indicated that the highest rated hp for a 289 was 210, but this did not say what the engine code was. I haven't looked at the rear end. Also, since this is different from the K code Mustang, they did come with autos from what I have been able to find out. Finally, the 5th didget in the VIN is a K, the 5th didget on the inner fender, driver's side, is a K, and the 5th didget on the title is a K, and on the original build sheet. If this ain't a K code Comet, which is different from the Mustang, then please tell me what all these Ks in the engine designation position mean?
Old 07-04-2007, 06:09 PM
Well Golfer I have read an awful lot of stuff about the 64. There was NO K code designation in the 5th digit in a Merc. Some info states there were Hi-Po Comets but ALL would have a A code. I cannot explain what you are describing. Can you post the vin or a copy of the build sheet?? DST ( Dearborn Steel Tubing )made the reliabilty run cars that had 289/271 engines in them. They were off assembly line cars. Either you have something very rare ( no information ) or someone may have tried to make a " K" code car thinking it was the same as a fairlane
1970bluel78
Old 07-04-2007, 06:43 PM
PeteLeathersac's Avatar
I'm no Ford guy but remember reading some info on these a couple years back when researching some Canadian Shell Endurance Rally stuff and I was searching for the Tour deFrance winning Mustang that actually ended up in Canada and disappeared..
Again I'm no Ford guy and I may be mixing up some of the Rally prepared car stuff I read but do recall the '64 Comets were being argued but ended up proven as definately built and had unique rears and ratios, distributors and underhood bracing also horsepower like 270...the big-car brakes were the rally cars only I think?.
I'll search and try and find what I read?.
Snce you have a build sheet, doesn't it show exactly what was shipped?.
~ Pete
