Old 06-30-2007, 12:14 PM
Chris396 Chris396 is offline
Default L78 tune up
It's time to tune up my L78. What are the valve lash specs?
Old 06-30-2007, 01:20 PM
Default Re: L78 tune up
Back in'66 I think GM was calling for .020 intake and .024 exhaust. By '70 they were calling for .024 and .028. Looser gives more bottom end torque. I run .022 intake and .024 exhaust with the stock cam. Our 427 ran almost 200K miles that way and our L78 about 30K since we bought it. Seems to work for us.
Old 06-30-2007, 06:47 PM
Chevy454 Chevy454 is offline
What cam was put in it when it was rebuilt? The cam card will tell what lash the manufacturer intended...our Crane/GM cam calls for 24/28, but someone told me the cam card on the same cam *now* calls for like 24/26?
Old 06-30-2007, 09:06 PM
As far as I know the engine is still stock.
Old 06-30-2007, 10:38 PM
Still stock, as in rebuilt to stock specs, or as in it's an untouched short block from back in the day with original guts? If so, 24/28 is where you'll wanna be...a little tighter is "ok", but *do not* go any looser...
Old 06-30-2007, 11:39 PM
Yes, rebuilt from what I know. Thanks.
Old 07-01-2007, 04:21 AM
@wot @wot is offline
What's "a little bit tighter", .001, .002, etc. Just curious.
Dean
Old 07-01-2007, 04:32 AM
Thereabouts...if you get too tight, the thing won't wanna rev and you're putting too much stress on the valvetrain...but conversely, too loose and you'll hammer your lifters to pieces. From .022-.028 is probably the safe zone assuming it's an older stock cam...I've seen a newer replacement cam with 16/16 figure, and then of course some of the newer tight lash cams take that a step further.
Old 07-01-2007, 06:50 AM
NCGuy68 NCGuy68 is offline
Is that setting them hot or cold?
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 07-01-2007, 08:20 AM
Hot, always hot...
