Old 06-29-2007, 08:29 PM
Johnny Horsepower Johnny Horsepower is offline
Default my 70Z dyno tune
for those of you who remember, i was having an issue with exhaust popping when backing off on my 70 Z28. We threw it on the dyno, and clamped the smog hoses. Cured it so we installled freeze plugs. We then decided to do a pull. Much to my chagrin, we discovered spark degredation at about 4850 rpm. Car would quit accelerating.
Now we have to hunt that down. We are going to start with the date coded wires. Any suggestions?
In the meantime the aborted pull to 4850....
300 rwhp 375 lbs
John
Old 06-29-2007, 08:34 PM
mockingbird812's Avatar
Default Re: my 70Z dyno tune
Nice numbers! Is that a stock set up?
Sam...
Old 06-29-2007, 08:42 PM
It is stock, however they may be inflated because our weight was a guess. I don't even remember how much we plugged in.
It is running stock compression, 100 oct race gas, and pertronix ignition.
Next time i pull, i will grab the weight off of nasty z28
John
Old 06-29-2007, 08:57 PM
I guess we were not that far off and in talking to my engine guru he said it really does not affect those numbers, just acceleration times.?.
Old 06-29-2007, 09:25 PM
PeteLeathersac's Avatar
Possible Coil failure at higher revs or distrib shaft bushings...plugs?.
~ Pete
Old 06-29-2007, 11:04 PM
~ Pete
Thanks Pete, Plugs and coil were on the list. I'll add dist shaft bushings.
John
Old 06-30-2007, 03:11 AM
MosportGreen66's Avatar
cool car
Old 06-29-2007, 08:38 PM
Some pics
John
[image]http://[/image] [image][/image] [image]http://[/image]
