Old 06-24-2007, 09:29 PM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
Default "CE" BLOCKS ---- Understanding this code
OK, wanted to have a final place to go to on this CE stamped Block issue.
Would like to have this post as a guide to CE useage, where it pertains to restored GM cars, specifically Camaros, Chevelles, Novas, Trucks, etc.
What is a CE stamp?
When did it begin?
How is it used?
Is their any GM documentation regarding the CE useage?
When was the last year a CE designation was stamped for distribution?
What blocks have been seen and used by GM with the CE stamping?
What is the correct warranty procedure used by GM to apply any CE stamped block/engine into our GM cars?
Anything else this should include that I am missing?
Chavez Ravine
Attachments - The Supercar Registry 276402-69L34assemblystamp002.jpg 276231-68_letter_CE_engines.jpg 276230-68_letter_CE_engines_ton.jpg
Old 06-25-2007, 03:00 AM
L34Pace L34Pace is offline
Default Re: "CE" BLOCKS ---- Understanding this code
Start with this.
Pat Railsback
67 0-1 Camaro L35/M40/3.07
68 RS/SS Camaro L78/M22/4.56
69 Z11 Camaro L34/M20/3.73
Old 06-25-2007, 03:02 AM
page 2
Pat Railsback
Old 06-25-2007, 09:28 AM
427king 427king is offline
Yenko Paid Member
CE stamping began with the #321 block as far as 427s go , the #323 was the first 396 block with a CE designation. They were both produced at about the same time and are 68 casting #s. Prior to that the warranty motors had a blank pad.
Old 06-25-2007, 06:23 PM
PeteLeathersac's Avatar
Wasn't there some 'X' code stampings on warranty and counter exchange blocks previous to the CE's?.
~ Pete
Old 06-25-2007, 09:44 PM
Here's a new development that those with CE blocks might want to check out. It seems that an assembly code was stamped on the blocks when applicable. You need to remove the starter to view it as its on the flat surface of the flange. It seems to consist of the month and year only excluding the day. I've found them on both Tonawanda and Flint blocks.
Pat Railsback
Old 07-02-2007, 02:39 AM
Unreal Unreal is offline
My 512 CE block has T089 on the flange. It also has a "4" about 2" from the T089. Any clue if that is significant?
Old 07-02-2007, 04:20 AM
@wot @wot is offline
Very interesting, did not know that!
Dean
Old 07-02-2007, 09:31 AM
rpoz11's Avatar
Ill have to dig mine out to check that; it's burried behind the pacecar...
Chavez Ravine
