Old 06-19-2007, 06:29 AM
427king 427king is offline
Yenko Paid Member
Default 2 ZL1 427s
2 zl1 427s...one is a new gm block and NOS parts...26K the other is 69 dated block #052,and all parts under construction will be dynoed and ready to drop in 35K ..If notice is given prior to build on 69 motor i can include NOS vintage parts for that motor also. Nos L88 crate motor,heads were used sparingly every other part is new including unused new block. 14900.00 many motors available MN copo 427s 15900.00 reral alt vin pieces. 2 yenko chevelle motors MQ 15900.00 also 67 Tri power 435s many dates long blocks 12900.00 parts
Old 06-19-2007, 06:43 AM
Yenko Paid Member
Default Re: 2 ZL1 427s
Original GM m22s w original gearsets.No supercases, m20 stamped cases or anything else. These are all as pulled out of original cars have 1968 thru 1972. 1995.00 and up depending on year. 1970 Lt1 Z28 turbo 400 1595.00 cw tag for L78 and Lt1 z28..12 bolt BV rear 1969 camaro w april ring and pinion oiriginal piece needs rebuild 2495.00 KK chevelle 410s case 1295.00 feb 69 original stamp used housing ...
