Old 06-15-2007, 11:19 PM
blackls6 blackls6 is offline
Default Question about Sound Deadener Under Sail Panel
Does anyone reproduce the molded sound deadner under the headliner side sail panels?
Old 06-15-2007, 11:31 PM
Default Re: Question about Sound Deadener Under Sail Panel
No one that I am aware of. Because it cannot be seen, I simply make my own. Much lighter and does a better job anyway. I use the same material that is used on the inside of the kick panels and under the dash.
Old 06-16-2007, 12:23 AM
Windber resto supply sells a waterproof panel board that I think is pretty similar to the stuff you're talking about. You can likely fashion something that will work. Give them a try. Windber Restoration Supply
Old 06-16-2007, 12:45 AM
Learn something every day.
