Old 05-31-2007, 06:39 AM
RUQUIK RUQUIK is offline
Default LS6 engine on ebay
Is the code CRR on this block 1970 only? Could this be a 1971 dated LS6? The ebay # is #120124977308
http://cgi.ebay.com/ebaymotors/ws/eBayIS...977308&rd=1,1
Old 05-31-2007, 06:47 AM
AutoInsane AutoInsane is offline
Default Re: LS6 engine on ebay
What car would this engine have been for?
Bill O'Brien
1974 Jeep CJ5 - 304 V8, Edelbrock Intake, Holley 650, MSD Ignition, Patriot Headers
Old 05-31-2007, 08:00 AM
wannaBBC wannaBBC is offline
according to my info yes the CRR is only a 70 suffix not 71,he states the date code B 7 71,, the seller might be mistaken on something I don't get it
Old 05-31-2007, 08:02 AM
pictures tell the story anyone figure this out
Old 05-31-2007, 08:03 AM
Ngtflyr Ngtflyr is offline
If his "show" cars looked as rough as the exterior of this engine I would hate to see his non "show" cars.
Dave
Old 05-31-2007, 08:08 AM
even the motor photos don't look correct , in the complete shot looks to have the high rise intake like the 163 , yet the intake shows the lowrise casting # 569,, go figure
Old 05-31-2007, 08:35 AM
I had a 72 396 with a 70 L78 code on the front pad last year. Consensus here was it was a marine engine, which I believe. This is probably the same case. The 163 intake was probably the one that came with the marine intake. The seller says the other(70-71 LS6) intake is also included.
Old 05-31-2007, 11:24 AM
LS6 RAT LS6 RAT is offline
This motor is just a CE assembly. I had a casting date of 1972 with a CRR coded assembly. It happened to use the 1972 casting number block, but it had all the correct internals and was a T0422CRR pad stamping.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 05-31-2007, 08:22 PM
JIM's Avatar
JIM JIM is offline
Ther were plenty of assembled engines sold over the counter in the early seventies that had codes . You could buy a complete LS-6 for No Money. They sold all of the engines that way. L-79's were like 370.00 for a complete longblock back then. There a lot more engines out there than You may think, That goes for all of them.
Jim
Old 05-31-2007, 09:12 PM
markjohnson's Avatar
Yep, that 'CRR' block stamping was used up until about 1972. Why they weren't stamped 'CE' like most other crate engines, I don't know. I currently have one of these 1972 CRR LS-6's in my '55 Chevy Gasser. It happens to be a '289' casting for the cylinder case but also has the closed chamber, rect. port cylinder heads and pancake aluminum intake manifold with all 1972 casting dates.
