Old 05-18-2007, 04:42 AM
427.060 427.060 is offline
Default Need Casting Numbers Help
I just picked up a set of brake calipers and need to verify the casting numbers. The numbers are 5456008 on one side of the caliper and 5455946 on the other. Both calipers have the same numbers. Should there be a difference in the right and left calipers?
Thank you, James
1968 Beaumont SD396
Old 05-19-2007, 06:46 PM
68Biscayne427 68Biscayne427 is offline
Default Re: Need Casting Numbers Help
Here is some info.... Can't vouch if it is correct..
http://www.camaros.net/forums/archiv...p/t-68720.html
Rob M.
'68 L-72 Biscayne, M22 4-speed
Old 05-23-2007, 03:21 AM
Thanks for the link. According to what they said, the calipers I have are the correct ones.
James
1968 Beaumont SD396
