Old 05-15-2007, 01:09 AM
Johnny Horsepower Johnny Horsepower is offline
Default Battery toppers
How many of you use and are satisifed with battery toppers as a product. I am considering getting some R59s for my pontiacs and I can't find one for my R89 side terminal battery on my 70Z28.
all thoughts are appreciated.
JOHN
Old 05-15-2007, 01:57 AM
1969z280 1969z280 is offline
Default Re: Battery toppers
John:
The battery toppers do the job just fine and actually look very good. Did you know that they are produced by Legendary Motor Cars in Canada. It's one of their little side lines.
The battery toppers are much less expensive than constant replacement of repro lead acid batteries. That's why I jumped on the bandwagon. I have seen them for Delco tar tops but never for a side terminal battery.
Good luck and post if you find one.
Ed
... some old Chevrolets and Pontiacs.
Old 05-15-2007, 02:40 AM
TDW TDW is offline
I use them on 3 different cars. They work great. All top post though.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 05-15-2007, 04:40 AM
Unreal Unreal is offline
I have one over my modern delco. Looks great from the top, but the sides are still "modern" Also, mine is not a tight fit. Some guys use velcro to keep it from sliding around, but I think I'll just glue some fillers on the underside to secure it.
Someone said the new repop from New Castle, I think, have a modern Optima sealed inside the repop case. If true, that would look more accurate from any angle.
Old 05-15-2007, 04:51 AM
Ok, so i talked to the guy in Iowa with the toppers. They do not have one for the R89 side post, but have been trying to get that done.
He made the point, and its a good one, that a good chunk of 70Zs depending on build date, would have come with a top post battery. So I guess I will go that route, a modern delco with a topper and keep my side post for any serious or judged shows. I also am going to convert my other pontiacs to Delcos and toppers (R59s). Although my collection is all hooked up to a ten bank battery tender, the repops just don;t do it. So I will do the same thing, save my acid R59s for showing and judging and do the toppers for my personal use.
I just put in the correct starter for my 69 TA and I still don;t have enough crank on hot starting to turn the starter strongly enough with my repop R59. I hope this solves some of my problems. It is extremely important for me to pick a ride and rip it whenever i get the itch.
JOHN
Old 05-15-2007, 05:06 AM
Z28DL Z28DL is offline
Hi John,
Do you have a link to the toppers that shows what they look like and cost? If so please post.
Dave L
SoCal
Old 05-15-2007, 06:58 AM
Gregs396 Gregs396 is offline
I have also been waiting for the side terminal version.....
Here is the link..
http://www.batterytoppers.com/main.html
Old 05-15-2007, 07:06 AM
Mr. Chevy's Avatar
I use one and love mine, works very nicely!!!
Old 05-15-2007, 05:19 PM
Will there be any change with the cables etc, when i go to a top post from my current side set up?
John
Old 05-15-2007, 05:46 PM
Steve Shauger's Avatar
Administrator
John:
Ed
My understanding is that they are still produced by Captain Carl in Iowa. Legendary Motor Car is not involved with this product.
www.vintagecertification.com
