Old 05-14-2007, 10:10 PM
mudjnky mudjnky is offline
Default 68 Deluxe Steering Wheel Wanted
I'm looking for the wheel only, cracks on the rim OK, trying for one that the base isn't split, I'm doing a test run on having one covered with leather, trying to stay real cheap as I don't know how well this going to work, Thnx!
Old 05-15-2007, 04:07 AM
427.060 427.060 is offline
Default Re: 68 Deluxe Steering Wheel Wanted
I have some of these steering wheels. I'll check to see what condition they are in and let you know. You don't need the shroud, correct?
James
1968 Beaumont SD396
Old 05-15-2007, 04:39 AM
Thanks James, no shroud, just a decent wheel
Old 05-15-2007, 05:34 AM
I found one that has an uncracked base but has 3 bad cracks on the rim. 2 are about 1/4" wide and the other is about 3/8" wide. It is also cracked at or near all 3 areas where the shroud screws go. I'll take $25 including shipping. If you are interested in this one PM me your email address and I'll send you a couple pictures.
James
James
1968 Beaumont SD396
Old 05-16-2007, 01:29 AM
Thanks, PM sent
Old 05-16-2007, 02:35 AM
Pictures are being sent now. You should have them in a few minutes.
James
1968 Beaumont SD396
