Old 05-05-2007, 07:24 PM
Default Green bumper crud?
When a chrome piece sits around for years in a damp environment it can get covered with a crusty green oxide of some sort. Does anybody know an easy way to clean it off...other than steel wool? Is there anything that will disolve it?
Thanks
Verne
Old 05-05-2007, 07:33 PM
Default Re: Green bumper crud?
Steel wool with water works great. Not sure of a easier way.
Old 05-05-2007, 07:47 PM
Belair62 Belair62 is offline
Its from the copper plating under the chrome I think Verne..actually the steel is pretty good to remove it...I dont know if you want to get chemically that deep to dissolve it
Old 05-05-2007, 08:40 PM
Try using an industrial volatile Toliet Bowl cleaner,not the standard household stuff.
Aim for the heavy duty stuff that has a skull &amp; crossbones on it,and warns of caustic fumes.
Cut it with a lil water first and if that doesn't move it,use it full stength but becareful as it may etch the plating now.
CLR remover might help too,but I find it has the same ingredients as most household Toliet Bowl cleaners anyway.
Old 05-05-2007, 09:06 PM
ORIGLS6 ORIGLS6 is offline
Sounds like the Chrome plating is already getting a little thin. I've used the Eagle 1 Chrome Wheel cleaner and some 0000 Steel Wool with pretty good results. The 0000 isn't that agressive and doesn't seem to eat through the chrome like a scotch-brite or the more coarse steel wool. Just be sure to rinse it thoroughly with clear water pretty quickly.
Old 05-06-2007, 12:57 AM
Thanks guys.
How about easy-off oven cleaner....or would that eat the chrome too?
Verne
Old 05-06-2007, 01:16 AM
kwhizz kwhizz is offline
If anyone would know about cleaning "OLD" chrome, it's Cumby.................LOL........LOL......
Ken
Old 05-06-2007, 05:19 AM
I used to like you!
Old 05-07-2007, 12:40 AM
firstgenaddict's Avatar
Try the www.safestrustremover.com
It removes rust and oxidation from everything...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 05-07-2007, 10:23 AM
Kurt S Kurt S is offline
&gt; Try the www.safestrustremover.com
I have the MSDS for that (also known as RidRust, Griots Garage rust remover, etc).
It's phosphoric acid.
Kurt S - CRG
