Old 05-04-2007, 06:44 PM
blackls6 blackls6 is offline
Default Correct Oil Dipstick for 1970 LS-6 Chevelle
Can anybody help me with figuring out which oil dipstick is correct for my car?
I have two flat yellow tip dipsticks that look exactly the same, except one has different wording.
I also have the one that you can get from GM still which has the round tube handle!
Is one of them factory installed or from the parts department?
1) USE SE ENGINE OIL with E side ways.
2) USE GM6041-M-QUALITY MS with E sideways.
I also have a flat blue tip dipstick that has #1's wording, what application does this fit?
Thanks! John
Old 05-04-2007, 07:15 PM
3macs1 3macs1 is offline
Default Re: Correct Oil Dipstick for 1970 LS-6 Chevelle
Boy am I ever glad you asked this question. I have been debating this with guys for a week now since I listed one of those yellow sticks on e-bay. Some are telling me the 6041 is the factory install and the SE Engine oil came later.
I say BS. I have three original 1970 LS-5 engines one pulled and stored since 1976 and two of the three never apart. All three have a yellow flat end stick with SE engine oil on it and they have never been changed. Then I have a NOS #5599 stick and it is the twin of these other three.Also have two 69 396 both of which once again never apart and bought from original owners, once again Use Se oil yellow sticks.The first 6041 stick I could find was in a 71 402.
I know the yellow round handle is not correct they came out probally in late 71/72 and could be bought over the counter.
The odds are in my favor with 4 untouched engines unless I am into one of those GM Canada things again and the US used the other stick.
Lets see what the guys have to say.
Old 05-04-2007, 07:31 PM
ORIGLS6 ORIGLS6 is offline
OK, I guess I'll have to check again tonite! Geez, you guys are forcing me to get intimate with the Black Mistress again.
Kinda funny actually. I've owned the car since 1970 and, thanks to this site, I'm still learning new things about it.
I'll file my report later.
Old 05-04-2007, 07:37 PM
It will be very interesting Dennis. I owned mine since 76. One thing that I should mention is the fact all 5 of the engines I checked were cast in 69. The earliest 454 was August 13th. None of them were 70 castings except the 71 402 which was real late 70.
Old 05-05-2007, 07:58 AM
I have a 71 402 engine that I bought 16 years ago and put in my 68 Camaro. It was never apart and I have the original dipstick. At the tip it has ADD 8, then two small circles on top of each other followed by FULL. Then USE GM 6041-M QUALITY MS OIL and a 1 inch gap followed by an M. The handle has what looks like a light green plastic tip.
Martin Foltz
68 Camaro SS-396
Old 05-05-2007, 09:09 PM
Mine is like John described his #2 piece, "USE GM6041-M-QUALITY MS with E sideways." It has the flattened round handle with the Yellow plug.
This is from an 05D Arlington car. The stamp pad reads "TO403CRR" with a block casting date of "B 27 70".
Old 05-05-2007, 09:18 PM
Interesting. Mine are all canadian engines Oshawa built cars and no 70 castings. I have a january 70 cast 402 at my brothers sitting a CTX I think out of a 70 Chevelle 4spd.I will have to check that one.
The sticks I have are are identical to Johns same length, location of fill marks etc.Nice to have someone check a original 69 casting to see what they have.
Old 05-05-2007, 09:54 PM
I think both of those designs can be considered correct for the 1970 LS-6,L-78,LS-5,L-34 LS-4 & LS-3,as long as it has a flat handle & margarine tip.
There are too many examples of both previously mentioned designs in many undisturbed vehicles.There was not one definitve dipstick.
There was also a third factory released design with just ENGINE OIL followed by a sideways E on it used on the line.
All three dipsticks were possible under part #5599 w/flat handle & margarine tip,as I would imagine they were made at regional Arvin plants/intervals.
Old 05-05-2007, 10:22 PM
Thanks Rick for the clarification. It makes perfect sense what you are saying. Do you remember approx when the round handle yellow end stick came out???
Old 05-06-2007, 05:10 PM
69L78's Avatar
69L78 69L78 is offline
My 12k org mile 69 L78 with build date Dec 68 just has Engine Oil with sideways E.
