Old 04-24-2007, 11:06 PM
Default Flywheel
Anyone know the specifics of flywheel #3791021?
Will it work on an L78?
Old 04-24-2007, 11:37 PM
Default Re: Flywheel
I've never seen it on any Big Blocks.
The flywheel is stamped #3791021,but Chevrolet recognizes it as #3971022.
It was used on nearly every Manual Trans.6 Cyl.& Small Block from 1964-1970.
Police-Taxi-Truck-Chevelle-Nova-Passenger w/153-194-230-250-283-307-327-350..and the 1967-69 Camaro w/302.
Old 04-25-2007, 12:01 AM
Hmmmm...... would it work on a BB?
Old 04-25-2007, 12:06 AM
Yes, the answer is that simple, yes! Having said that, my question would be does it have bolt holes for a 10.5 inch pressure or for a 11 inch pressure plate? <font color="green"> </font>
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 04-25-2007, 11:53 PM
Not sure about the holes.
Is it possible to use a 403 bellhousing (10.5" clutch) with an 11" flywheel?
Old 04-26-2007, 01:46 AM
No I dont think the bellhousing will clear the flywheel.
Jake is my grandson!!
Old 04-26-2007, 01:47 AM
11" only clears "621" or the other truck BH.
Old 04-26-2007, 01:51 AM
Ok, thanks!
Old 04-26-2007, 06:06 AM
My 72 SS has a 11" PP and factory stock is a 10.5" PP. The cast iron flywheels I have for both of these PP's have the same diameter ring gears on them, the aluminum one on it now is drilled for both 11" and 10.5" (diaphram style). I still think it will fit.
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 04-26-2007, 07:09 PM
The "621" measures 16 3/4" and the "403" is 16 1/4" That 1/2" is why the 11" flywheel will work only in the 621 &amp; 444 bellhousing. Kim
