Old 04-14-2007, 11:59 PM
Dog427435's Avatar
Default The 1963 Z-11 427 Impala
The R.P.O. Z-11 optioned Impala was designed for one reason and one reason only... Racing. Cubic inches were climbing fast in '63 and the Z-11 427 Impala was Chevrolet's way of keeping up with Ford, Pontiac, and Chrysler at the track.
The 427 was a modified 409 engine. The stroke was increased, special heads, valves and intake manifold were added. Fuel was supplied by 2-4bbl Carter AFB carburetors. A special cowl induction air cleaner was also used.
This car was all performance and no frills. You wouldn't find a radio or even a front sway bar. Most Z-11's were ordered with the heater delete option and no sound deadner. Light and fast was the idea with this car and to help lighten it, the Z-11 came with an aluminum front nose and other parts. Hood, fenders, front and rear bumper, front and rear bumper brackets and braces, grill brackets, a 2 piece riveted fan shroud, grill filler panel and hood support catch were all made from light weight aluminum making the car about 300 pounds lighter than a similar 409 powered production car.
To stop the car, sintered metallic brakes and special venting screens and air scoops in the backing plates for added cooling were used. All Z-11's came with T-10 4 speeds, a beefed up posi rear and a 4.11:1 gear ratio. (code JA)
Only 57 Z-11 optioned Impala's were produced and only 7 are thought to be in existance today, making them an extremely rare and valuable piece of Chevrolet history.
Although the Z-11 was made for racing, they weren't directly sold to race car drivers. Some ended up on car lots. And although 1963 was the only year for the Z-11, there were about 20 C.O.P.O. 1962 Impala's built mid to late in the year with aluminum front ends and equipped with 409's. These 409's had special features like the Z-11 intake manifold, special camshaft, heads, etc. There were also 18 extra sets of aluminum front ends made for that year and sold to race car drivers.
The base price of a 1963 Impala was $2774.00. Adding the price of the R.P.O. Z-11 option of $1240.00 to that brings the total price just over $4000.00 not including destination charges, taxes, etc.
Z-11 Facts and part numbers:
Produced only in 1963
The R.P.O. Z-11 option was an additional $1240.00
Shipping weight-3245 lbs.
Curb weight-3405 lbs.
57 Z-11 Impala's were produced
Only 7 are known to be in existance today
Modified 409 engine rated at 430hp@6000 RPM's. (Actual
horsepower was 480-525)
Block casting #3830814. Code "QM"
Block part number #3838253
Cylinder Heads #3837731 2.19 intake/1.72 exhaust
Valve Covers #3837739 (left), #3837740 (right)
Oil pan (deep sump) #3816322
2 piece Intake manifold #3830623 (top)-#3837733 (bottom)
Waterpump #3837691 (aluminum)
Cam #3837736 .556 intake/.556 exhaust lift with 325 duration
Crankshaft #3837472
Distributor #1111023
Coil #1115107
Generator #1100628
Starter #1107274
3.65" piston stroke
4.3125" bore (same as 409)
13.5:1 compression ratio
Special cowl induction air cleaner #6418986, #3839764 (duct)
Tach (redlined at 6200 rpm's)
Borg Warner T-10 4 speed transmission (close ratio)
Special posi rear with 4.11:1 rear gear ratio
Sintered metallic brake shoes
Screened rear brake backing plates with air scoops
15 X 5.5 wheels with 6.70 X 15 bias ply tires
Front coil springs #3824693
Rear coil springs #3824694
Deleted front sway bar
Optional sound proofing and insulation delete on most
Optional heater delete on most
Hood #3837710 (aluminum)
Hood catch #3837718 (aluminum)
Grill filler panel #3837750 (aluminum)
Left fender #3837765 (aluminum)
Right fender #3837766 (aluminum)
Front bumper center #3837751 (aluminum)
Front bumper LH #3837755 (aluminum)
Front bumper RH #3837756 (aluminum)
Rear bumper center #3837752 (aluminum)
Rear bumper LH #3837753 (aluminum)
Rear bumper RH #3837754 (aluminum)
Front bumper bracket LH #3837763 (aluminum)
Front bumper bracket RH #3837764 (aluminum)
Rear bumper bracket LH #3837757 (aluminum)
Rear bumper bracket RH #3837758 (aluminum)
Rear frame to bumper brace LH #3837759 (aluminum)
Rear frame to bumper brace RH #3837760 (aluminum)
Thanks to http://www.348-409.com/ for all the above info
[b]Finding one of these 7 beauties is tough - but going to a show and seeing 2 side by side is amazing!!
One completely stock and the other in race trim!!
Old 04-15-2007, 12:20 AM
1969l78 1969l78 is offline
Default Re: The 1963 Z-11 427 Impala
Very nice
Old 04-15-2007, 01:09 AM
Tarrytown SS427s Tarrytown SS427s is offline
Those are awesome cars. I saw them at the GM nationals several years ago with the Old Reliable, and than saw the Old Reliable by itself last May at Musclepalooza. I think the owner is Don Fezell. My father has Z-11 waterpump..I wish he had the rest of the car!
Steve
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
Old 04-15-2007, 01:13 AM
tom406 tom406 is offline
I know it has a terrific caretaker, but that Alan Green car really needs to come "home" to Seattle. Maybe I should start putting my nickels in a jar.....
Old 04-15-2007, 04:34 AM
ANDY M's Avatar
ANDY M ANDY M is offline
and a whole lotta dimes.
Watching the "Sox Sinclair Service" Z-11 staging at the SCR last year beat all of the cars I've seen with velvet ropes around them.
https://www.yenko.net/ubbthreads/show...0/fpart/6/vc/1
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 04-15-2007, 04:38 AM
markjohnson's Avatar
In my opinion, Chevrolet's maximum drag racing effort was the 1963 Z-11 Impala. A close second would have to be the 1969 ZL-1 Camaro. Everything else was street cars. The number of special components on a real Z-11 is unbelievable. Can you even imagine what would have been produced in '64-65 if the GM ban on racing did not go into effect in mid 1963?
Old 04-15-2007, 06:49 AM
Belair62 Belair62 is offline
By far the most significant dedicated drag racing RPO ever built by Chevrolet. Would have been really cool to see the one at SCR driven hard. Can't say I blame him...breakage is not a real good thing with something like that...
