Old 04-09-2007, 01:29 PM
Tom Hartman Tom Hartman is offline
Default Sun Tachometer
I have a Sun Tach model # ST-601. Do I need anything special to hook this up? There are two wires out of the back, a red and green. Can I use this with electronic ignition or am I asking for trouble? Thanks in advance for your help.
Tom
Old 04-10-2007, 05:47 AM
67BobcatGTO 67BobcatGTO is offline
Default Re: Sun Tachometer
I can convert the tach to modern electronic internals if you are interested. It will not work as is with an electronic ignition set-up. thanks
Mike
www.instrument-specialties.com
Old 04-10-2007, 09:39 AM
Thanks for the reply Mike, I will be in touch. I have had the Tach since 1974 and wasn't sure if it needed a transmitter or not. I am not even sure what year it is. I will e-mail you.
Tom
