Old 04-05-2007, 07:08 AM
myhot69 myhot69 is offline
Default Mega Parts List #2
this is a first come first get deal the first email i get saying i will take this item gets 1st shot if they dont pay the next man gets the item.
If you dont want it for the price listed dont buy it! This is not ebay if you want to pay ebay prices GO!
I ship items after a MO is recieved, and send you the tracking #. I do not accept paypal,
If you are asking questions about an item and someone elce says I WILL TAKE IT, IT'S THERES NOT YOURS.
If you Cant put a MO in my hands within a week i will sell the item again, but if you notify me via email its truthfully on its way thats fine.
If you are looking for restored or Perfect NOS, all items unless noted are all used 38+ year old pull off parts, i am verry honest about the discription
I DO NOT ANSWER PMs EMAIL ME!!!!!!!! [email protected]
or call me my cell number is 803-645-1749
Here is a list of items i have for sale, I can take pics of the items you are looking for just let me know. all prices are plus shipping via UPS
* 69 chevelle/camaro/nova original disk brake callipers L&R set #s 637 & 638 working with dot3 fluid 3 mos ago and pulled to install dot5 fluid 50.00 for the pair
* 69 Chevelle jack assembally all #s correct U69 base, O lug wrench, jack staff & head Patent#3163925 150.00
* 293 B-R coil and original brackett, bolt and condensor 40.00
* 71 Chevelle front bumper bracketts, i belive these are correct for 70-72? 25.00set
* Camaro/Chevelle/Nova SB Heads # 3932441 SB dated E 19 9 & F 19 9 Need rework but came off a running engine I had and drove (ben dry in my garage 10+ yrs) 150.00set
* Headlight Bucketts and rings from 69 chevelle good cond. no rust, set of 4 2sets 15.00set
* Manley 100 thousants longer pushrods for BB with Dart heads, intake side 8.450 X 3/8 # 25845 4130 swedged end pro series 8pc in orig box 20.00
* 69 Chevelle/camaro/nova RH SB exhaust manifold # 3932376 dated A 7 9 great cond. with orig studs and flapper no heat sheild 40.00
* 69 Chevelle/camaro/nova RH SB exhaust manifold # 3932376 dated CorG? 2 9 great cond. with orig studs and flapper w/heat sheild but loose 40.00
* 69 Z-28 302 Camaro/Nova/Chevelle LH exhaust manifold # 3942527 with smog holes dated A 11 9 perfect cond. with orig studs,nuts and 3 hole pipe holder 350.00
* 69 chevelle AC or Non AC elbow shutoffs for ball vents L&R 2 sets 20.00set
* 69 chevelle AC ducts 2 or 3 of every one under the dash email me with a description of the ones you need.
* 68 chevelle/camaro/nova BB quadrajet intake cast iron # 3883948 dated L 28 7 for 68 car 50.00
* Tag Flip down holders for 69 camaro/chevelle GM original part with #s on back 2pc 20.00ea
* 69 chevelle 6000 redline tach and guages real deal not a repop, tach, gas and temp work perfect but i couldnt test amp guage Looks GREAT 650.00
* 69 chevelle SS396 dash strip above glove box 70.00 has a verry small place in corner but good driver quality
* Hurst Comp + shifters 2 pc both look to be 67-69 camaro some linkage with each 50.00ea.
* 68-72 chevelle wiper arms 3sets 20.00 & up per set
* 69 ElCamino smugglers box cover (bolts to bed) 20.00
* BB stock rods and caps from 325/350HP bigblock 3/8 bolts good cond. 25.00
* 68-69 chevelle verry rare plastic clips for the rear strips below decklid these fit the oval holes (complete set good used) 40.00
* 67-69?camaro (came out of a 69) fiberglass wheelwells used but in good condition 50.00 for set will try to work out shipping if you cant pickup but there big
* 68-69 Chevelle front fender braces (bottom front to rad support) 1set 20.00 per set
* 69 Camaro NEW Vinyl top and aftermarket vinyl top crome trim new in box and pack 75.00 for all
* BB chevelle and camaro/nova dipsticks with yellow tip (no #s) with tube 2 pc 25.00 ea
* BB 69 chevelle/camaro/nova 418 starter dated 9 H 19 also correct for early 70 BB 4 speed car LS6 & LS5 & all 396s, all COPO YENKOs has the original solonoid and works 150.00
* metal headliner trim L&R set from 69 chevelle 3 sets 30.00 per set
* chevelle door hinges 3 sets all have good rollers (i would rebushing) 25.00 per set of 4
* non tilt floor shift stering collum 69-72 chevelle with key complete and tight 50.00
* rear seat from 70-72 chevelle good foam and springs need covers will try to work out shipping 50.00
* rear view mirrors all from 69 chevelles but are the same on 68-72 chevelles, camaros? 5pc 10.00ea
* Trunk latch (on decklid with original bolts) 2 pc 20.00ea.
* emergency brake foot pedal assembally 1 from 70-72 chevelle 3 from 68-69 chevelle 20.00ea
* 12 bolt rear end cover original from 69 chevelle/Camaro 25.00
* clutch and brake pedal setup from 4 speed 69 chevelles 2 sets 80.00 per set
* tail light bezels all original OK condition 20.00 per set
* tail light housings with good studs 4 sets 25.00 per set
* tail light lenses all original 38 yr old 1 set 25.00pr
* vent ball assemballys pass side and drivers side 3 of each side 10.00ea
* kick pannells 1 set of black non AC 3 sets of AC blue from 69 chevelle but will fit 68-72 nonAC 75.00 AC 40.00
* 69 chevelle speedo cables all used from 69 ss 4 pc 15.00 ea
* MC1 Muncie 3 speed cast iron transmission with the original muncie shifter from a 69 chevelle SS 125.00
* Loads of small parts from 69 chevelle inside and out just email me and ask
* 69 chevelle dash bezels better than average condition have 4pc 3AC 40.00 and up
* 69 chevelle heater workings inside of car Non AC have1 50.00ea AC have 3 45.00ea
* heater controls 69 AC have3 20.00 69 non AC have2 20.00ea 71 AC have 1 20.00
* 70 - 72 chevelle door window regulators both sides 25.00
* 69 - 72 chevelle buckett seat headrests, good condition saddle colored but can dye 50.00
* 69 chevelle jack assembally Not numbered on staff or base but has 69 chevelle hook and lug wrench 40.00
* 70-72 chevelle under stering collum cover, green but can be painted to match interior 15.00
* 69 chevelle probubly 68 too AC style gove box compartment (not broken) 20.00
* 69 camaro Z-28 waterpump # 3953692 dated F 20 9 50.00
* window regulators 4 for each window of a coupe 69 chevelle 20.00ea or 50.00 for set of all 4 windows
* 69 chevelle ash tray with brackett, black but can be painted any color to match dash 35.00
* complete set of 4 original deep dish SS caps and retainers good driver quality but replate for show 50.00
* SB cast iron 300 hp intake # 8927184 dated J 18 8 50.00
* BB cast iron intake 325 or 350 hp 396 # 3931067 dated F 19 9 50.00
* 69 camaro or chevelle alternator # 1100834 61amp 1 dated 9 C 21 & 1 dated 9 F 2 (no fan or pully) for all 69s W/O AC except 375HP 35.00
* 69 camaro or chevelle alternator # 1100843 37 amp 1 dated 8 L 22 (hard to read #s) & 1 dated 9 F 26 for all 69s with AC any engine incl BB 35.00
* BB Left exhaust manifold for # 3892307 dated K 23 5 Impala 396 and 427 20.00
* 69 Camaro or 70 Chevelle standard stering wheel center with horn buttons Blue in good condition (leather grain) (had 1 verry small crack but repaired verry nicely) 20.00
* rear bumper brackets complete set of 3 pc no pits 2sets 25.00 ea
* partial set of brown deluxe seatbelts OK condition great partial set dated 30.00
* T3 headlights 5 low beams 13 high beams all work sold in sets 150.00 for all
* 4 speed guage housings NO GUAGES just the plastic for a 4 speed car 2pcs 15.00 ea
* 70-72 chevelle AC vents center vent - passenger lower dash vent - drivers lower dash vent with stering collum cover 50.00 all
* Upper control arms for 68 - 72 chevelle 3sets 30.00 set
* rear window trim 2sets 35.00 & up
* hidden wiper metal windshield trim (under wiper blades when parked) 4pcs 20.00ea
* wiper transmission rods (complete setup with good pin) 2pcs 30.00 ea
* wiper motor complete with washer 1pcs 35.00 ea
* front bumper bracketts for 69 chevelle 2 sets 40.00 set
* hood latch for 69 chevelle 2 pcs 20.00 ea
* hood part of hood latch (bolts to hood) 20.00
* 69 chevelle hood hinges 3 sets 25.00 set
* 69 chevelle drip rail crome (sets or pieces) 1 full set and some pieces 40.00 for set
* door weatherstriping crome (around door glasses) 4 sets 20.00 set
* 69 chevelle headliner rods 4 sets 20.00 set
* 69 chevelle headliner metal pcs that flexable headliner surround trim hooks on 3 sets 20.00
* 71 chevelle metal headlight extentions (Bolts to fenders and holds parklights) 20.00for the pair
* 69 chevelle wiring harnesses, AC but will need to look at condition depending on your car
* 69 chevelle forward lamp harnesses or rear harnesses will need to look also depending on your car
* 68-72 4 speed or auto crossmembers 1 - 4 speed 5 auto 4 speed 75.00 auto 25.00
* 69 chevelle (fits 68 - 72) original decklid No Rust Great Condition Will not ship 200.00
* original radiator support bolts/body bushing and washers for chevelle, camaro, nova. these are original bolts 38 years old they are in good shape for their age with the
lg washers and nuts 25,00 per set 2sets
AND MUCH MORE EMAIL ME FOR YOUR NEEDS Thanks
Old 04-05-2007, 03:47 PM
Default Re: Mega Parts List #2
I will take the following:
* Dics Brake Calipers
* 293 BR Coil
* Radiator Support Bolts and Bushings
Sent e-mail
Paul
Old 04-05-2007, 07:38 PM
Donnie's Avatar
Donnie Donnie is offline
can you send pics please [email protected]
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-05-2007, 10:55 PM
Darryl,
E-mail sent.
Rick
Old 04-05-2007, 11:14 PM
JIM's Avatar
JIM JIM is offline
Are you coming to charlotte next week ? If so can You bring the MC1 3spd
Jim
Old 04-05-2007, 11:27 PM
Darryl,
Thank you for the very prompt response and the pictures. I appreciate dealing with someone who is so helpful on their parts for a change.
Rick
Old 04-06-2007, 12:57 AM
I will be in Charlotte NC next week at the swap meet so if this helps anyone let me know
Thanks Darryl
the following items are sold.
Shifters
MC1 3 speed trans setup
1 BB dipstick
69 camaro vinyl top stuff
4 speed crossmember
1 set of 69 chevelle bumper bracketts
1 hood latch assembally U&L
2 sets of hood hinges
6000 redline tach
#ered 69 jack
12 bolt cover
and maybe a few i havent wrote down yet
Old 04-06-2007, 03:46 AM
updated list of stuff left
* chevelle door hinges 2 sets all have good rollers (i would rebushing) 25.00 per set of 4
* kick pannells 3 sets of AC blue from 69 chevelle but will fit 68-72 AC 40.00
* 69 chevelle dash bezels better than average condition have 3AC 40.00 and up
* hood latch for 69 chevelle 1 pcs 20.00 ea
* 69 chevelle hood hinges 1 sets 25.00 set
* 68-72 4 speed or auto crossmembers 4 auto auto 25.00
Old 04-06-2007, 04:24 AM
it wont let me edit so here is the newest list of the stuff i still have
** 69 chevelle/camaro/nova original disk brake callipers L&R set #s 637 & 638 working with dot3 fluid 3 mos ago and pulled to install dot5 fluid 50.00 for the pair
* 69 camaro or chevelle alternator # 1100834 61amp 1 dated 9 C 21 for all 69s W/AC 35.00
* 69 camaro or chevelle alternator # 1100843 37 amp 1 dated 8 L 22 (hard to read #s) & 1 dated 9 F 26 for all 69s W/O AC except 375HP 35.00
Old 04-06-2007, 05:49 AM
chevelleheart chevelleheart is offline
Darryl , 1 other thing , Although I think I'm spelling your name wrong everytime I spell it, You didn't have a 1970 Chevelle 4557 carb did you ? Or even a 4491 ? Thx Bob
Lately into Beaumont SD's, 66,67,68 and 69 , including a 69 2 Dr Post Beaumont , an L78 2 Dr Post Chevelle LS6 Chevelle's, LS6 and L78 El Camino and Camaro fan ! Also 2 Cdn Documented COPO's, a COPO Camaro and COPO Chevelle Love GM Products
