Old 03-30-2007, 11:38 PM
Default Any 1969 Camaro Mechanics in Los Angeles area?
I believe I need to have the turn signal mechanism changed in my column as my turn signal indicators are not working and and the tail lights and front lights aren't evenly bright. Also, when I put the emergency flashers on, even my dash light and console lights flash on and off instead of just the indicator lights.
Does anyone live near Van Nuys who is interested in helping me fix this or know of a place I can take my car to?
Thanks
Old 03-31-2007, 06:53 AM
Plowman's Avatar
Plowman Plowman is offline
Default Re: Any 1969 Camaro Mechanics in Los Angeles area?
Sounds like you lost your dash ground. Run a jumper wire from the dash to the (-)bat. Try that test. GOOD LUCK Paul.
Old 03-31-2007, 08:18 AM
Have you had the column apart recently?
Sounds like the internal column ground circuit wire is pinched.
Check to see if the ground slug behind the headlamp switch knob is contacting/lose too.
