Old 03-28-2007, 09:19 PM
Default AG vs. YH Rally Wheel Offset???
Hello,
I have two YH rally wheels on the rear and 2 AG rally wheels on the front.
Does anyone know if the offset is different on these wheels?
Or where can I get that kind of information?
The AG's came on 68 corvettes from what I am finding and the YH are of course for a 69 Z28.
While looking down the side of the car I do not want one wheel sticking out further than the other wheel. If it does then I of course want the ones that sticks out on the rear.
Right now I can not tell visually. But maybe someone else out there would notice.
Hope this makes sense.
Anthony
Old 03-28-2007, 10:07 PM
Default Re: AG vs. YH Rally Wheel Offset???
If this helps,Colvin says the AG has a negative.28 offset,while the YH has just a .30 offset.
Old 03-28-2007, 10:16 PM
"Colvin says the AG has a negative.28 offset,while the YH has just a .30 offset."
Does that mean the AG's will be tucked in the fender wells .2 more than the YH's? So the YH will stick out a hair more than the AG's?
Thanks for the help!
Old 03-29-2007, 12:52 AM
I had a couple of AG's a while back that I traded, and I believe they will stick out farther, rather than be tucked in more. If you are not concerned with correct stampings, you should be able to find some later FW wheels cheap (if some crook hasn't already restamped them as YH wheels). I believe they are the same offset.
Lynn
Old 03-29-2007, 01:05 AM
3macs1 3macs1 is offline
I don't have a book to check but what about DC. I thought they were the same as YH also.
Old 03-29-2007, 01:11 AM
DC is a 15X6 w/.06 offset,compared to the YH 15X7 w/.30 offset.
Old 03-29-2007, 01:21 AM
Thanks Rick I am only going off the top of my head which is not great any more. DC's we use on the big chevs and I remember using a camaro or vette rim also. Like I said I don't have a book maybe it was YS not YH, is YS a 15 x6 same as a DC
Old 03-29-2007, 01:24 AM
Why yes it is.
Old 03-29-2007, 01:26 AM
Well 1/2 of the mind is OK. I remembered the Y part.
Thanks Buddy
Old 03-29-2007, 01:27 AM
I will eventually find two more date coded YH wheels to match my other 3, but for now these are going to be just fine....just want to make sure I have the ones that will stick out in the back!
thanks for the help!
