Old 03-23-2007, 07:36 AM
Default 1969 Camaro parts
------Have some stuff off a 69 Z Im doing that would be good for a driver. All cheap or free.
------All window glass except windshield. Will not ship. Not perfect but good useable. Ill have to check, but I think its all original glass. Come and get em.
------Original small-block fan shroud. Has small 1 or 2 inch crack. $20.00
------Original non-RS tail-lights and buckets. Decent useable condition. One or two small cracks. Will look good cleaned and polished. $30.00
------Original 120mph speedo. Actually very nice. Odo says 57,000. Needle bright and face excellent. No downside to this in any Camaro, even a showcar! $65.00. Repops list at $189.95!
------Two rear small bumper guards. Decent! $20.00
------One piece front antenna. Nice! $20.00
------Original drivers side Z exhaust manifold. Good smog hole threads. Appears to be some repair around two of the three stud holes, but threads are good and pipes seal OK. Already faced the head side. Date is April 69 (cant remember the day). Painted with something rust retarding and gray cast colored. $400.00 or offer.
------Non-Z small-block passenger side exhaust manifold also with good smog holes. Heat shield gone. A little warped as I can see the outer holes have been reamed some to get the bolts in. Same paint as above and also faced. $50.00 or a gift with the Z manifold.
------Repop black carpet. Front and rear. Not too old and not faded bad at all but will need to be shampooed for sure. $40.00
------4 15 inch Radial TAs. Hardly any wear. Fit a standard wheel-well, stock height 69 on the stock rims. I am going by memory but I think they are 225/60s but possibly might be 235/60s. Ill get the size right tomorrow. Would rather not ship these either. $200.00 for the set.
------I may add more tomorrow. I am located about 40/50 miles north east of Detroit. Thanks!!!.......Bill S
