Old 03-20-2007, 12:35 AM
kwhizz kwhizz is offline
Default Cannister Filters
Anyone have any tips........My cannister filter assy on the 66 is dripping........I took it off , added a new Filter and Gasket and it still dripped.......I had another Cannister, so I changed the Cannister, Gasket, and filter again and it still drips.........any advice.....
Thanks
Ken
Old 03-20-2007, 12:43 AM
Default Re: Cannister Filters
Yeah, dont look under your car anymore.
But serioulsy folks, there is also an O-ring or sealing washer that goes under the long bolt I believe. That never gets replaced and always drips.
Old 03-20-2007, 01:25 AM
ORIGLS6 ORIGLS6 is offline
Thanks
Ken
Depends!
Oops! I mean, it depends on where the drip is. Like Steve said, the gasket around the bold is likely the culprit, but you could also check the "O" ring up inside the block. Maybe there's something between the machined surface and the "O" ring.
Old 03-20-2007, 01:31 AM
I forgot to mention that this is on the Rebuilt Engine that just went back in the Chevelle......Didn't leak before..Noticed it right after start up, not much ....just a couple of drips.......It's not coming from the Oil Pressure port...Bone dry there, but I can see where the drip ran down the Outside of the Cannister???????
Maybe I should take the filter adaptor out of the Block and change the Gasket there, but I think the Cannister Gasket bulges out and seals the outside of the Cannister also?????
Ken
Old 03-20-2007, 01:36 AM
Ken,
Is there a check/by pass valve in the adapter?
Old 03-20-2007, 01:39 AM
Yep!!!!!
Old 03-20-2007, 05:59 PM
How much oil pressure you running??
Jake is my grandson!!
Old 03-20-2007, 08:55 PM
427TJ's Avatar
427TJ 427TJ is offline
Crack in the cannsiter/adaptor? Double gaskets by accident? Just mentioning the "duh" items.
Old 03-20-2007, 09:28 PM
Stock Pump.......Gonna pull it apart tonight and look at everything closer........
Ken
One of these days I'll have a car that doesn't leak oil................
Old 03-20-2007, 10:29 PM
Me soon as I sell my FORD!!!
