Old 03-11-2007, 07:39 PM
Default Mopar clutch question???
I found an aftermarket 130 tooth 8-bolt hemi flywheel with a single bolt pattern on it. I need to know what the bolt pattern is for the factory 10.95 clutch. I measured across the flywheel and it is 11-3/4" from the center of one bolt across to the center of the other bolt. Does this match the factory clutch plate bolt pattern? Does anyone have an old clutch they can measure across to see if they are the same. Like a dummy I threw out the old clutch from my hemi a year ago during a cleaning binge..."Oh, I wont need that used clutch for anything"...DOH! Thanks.
