Old 02-20-2007, 01:01 AM
Jeff H Jeff H is offline
Default Holley carb power valve questions
I'm rebuilding a Holley 4557 for my 70 L78 Camaro. It looks like it had a 10.5 primary and an 8.5 secondayr power valve. The rebuild kit looks like it has a pair 6.5 valves? Is that too low to go compared to stock? This carb is really old and has been sitting for years so I'm doing a cleaning and rebuild and can't compare before and after. I'm thinking I need to stick with someting closer to stock instead of the 6.5's that are in the kit.
Old 02-20-2007, 01:25 AM
JoeG JoeG is offline
Default Re: Holley carb power valve questions
I'm running the same power valve numbers 10.5/pri--8.5/sec on a 3310 that I use on and off and the car responds real good and idles well with no surging--Bring your engine to operating temp and take a vac.reading and then step down 2 numbers....to start.
Old 02-20-2007, 01:55 AM
Our L72 engine came with 6.5 poweR valves front and back.
Old 02-20-2007, 02:08 AM
VintageMusclecar's Avatar
Jeff;
The original power valves for a 4557 are 8.5's both front & rear. If your engine is stock, I'd stick to that.
Eric
Old 02-20-2007, 02:29 AM
The engine has 2" primary headers, HEI distributor, I think they're 1971 oval port heads(to lower compression), stock flat L78 intake and I'm going to assume stock cam. If I remember correctly, when I checked the compression and vacuum it was reading around 13 at idle. So I'm thinking the 6.5's will be too low. I would rather get the power valves right the first try so I'm in no hurry. Thanks guys.
Old 02-20-2007, 02:38 AM
Jeff;
Check your PM's.
Eric
Old 02-20-2007, 03:20 AM
Chevy454 Chevy454 is offline
We run a 65 in the front and a plug in the rear of ours...seems to work...
Old 02-20-2007, 06:07 PM
Ditto that setup on the Deuce
Old 02-20-2007, 11:41 PM
Just curious..Are you both using the 6.5 PV with the window openings...........
Old 02-22-2007, 05:03 AM
They're just plain old off the shelf pv's, but "yes", I believe they do indeed have the windows...
