Old 01-16-2007, 02:55 PM
BillD BillD is offline
Default WT Master Cylinder 5460346 from 68 Power Disc Cama
WT Master Cylinder 5460346 from 68 Power Disc Camaro. Rebuildable core is OK, or rebuilt.
Bill D
Old 01-17-2007, 10:06 PM
bigchevydaddy bigchevydaddy is offline
Default Re: WT Master Cylinder 5460346 from 68 Power Disc Cama
There's two on ebay now.
Core: http://cgi.ebay.com/ebaymotors/67-68-CAM...sspagenameZWDVW
And rebuilt: http://cgi.ebay.com/ebaymotors/1967-68-6...sspagenameZWDVW
Good luck, BCD.
Old 01-18-2007, 12:00 AM
BigChevyDaddy. Thanks, You bring up a good point. Both Master Cylinders have the correct casting, but are they a correct replacement for the WT? I know they will work and they look correct but doesn't a WT have its' own specific internal specs? I can live with not having the WT stamp for the car it is going on. I just want it to look correct and perform correctly. Any opinions?
Old 01-18-2007, 01:14 AM
I'll have to let the brake experts answer that one; but I know that my local rebuilder works from the Cardone application manual and cross-references the applications from the casting number (so I think they would work for your '68 Z).
Good luck with your search! BCD.
