Old 01-01-2007, 04:26 AM
Default Day two Camaro traction bars
Hi all !
I have a question about period correct ( I will explain )
traction bars. Are there any differences between the
traction bars available today & those installed back in the
day?
If someone was going to restore a day two car today, would
they look for a specific traction bar make & model? What
color(s) were the traction bars back in the day? Did any
of the Supercar dealers install traction bars as part of
their performance package?
I have started a pseudo-collection of day-two items and I'd
like to get a set of traction bars that would have been
originally installed by a day-two dealership.
Steve
Old 01-01-2007, 07:19 AM
firstgenaddict's Avatar
Default Re: Day two Camaro traction bars
Here are a set of day two bars... Lakewood.. Yellow.. designed by Grumpy... and the same ones Hot Rod used in their 69 Z build up in April of 69...
Close up
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 01-01-2007, 07:22 AM
James,
Are those Lakewood bars any different from the ones available today? Look at this eBay auction that just
ended. Are they the same? Lakewood Traction Bars
Steve
Old 01-01-2007, 07:30 AM
x  Baldwin  Motion's Avatar
Close up
beautiful RS Z, what happened to that gas tank?
Old 01-01-2007, 07:31 AM
Same ones...
They are supposed to be really good. You can set the preload... find the April 69 (99% sure that is the month) issue of Hot Rod... they give the low down on getting the most out of the 69 Z.
~JAG~
NCRS#65120
Old 01-01-2007, 07:37 AM
The gas tank was crushed in more than that. I took it off to replace the sending unit and pushed it back out as much as possible. It has the original markings on the top which also match the heater box so we decided to leave it... as the car is very original... 99% interior and 90% paint. As well as all of the phosphating under the hood etc...
I cleaned the outside of the gas tank and then took some zinc rich primer and rubbed it into the few places of surface rust on the tank... over all it looks pretty good compared to what it looked like before...
Here is a link to the rest of the photos... http://www.crossroadspaper.com/1969_...otoGallery.htm
~JAG~
NCRS#65120
Old 01-01-2007, 07:40 AM
427TJ's Avatar
427TJ 427TJ is offline
Here's what Nickey traction bars looked like for the then-new '67 Camaro (with 427 conversion). Bars were originally designed for Chevy II with V8 conversions by Bill Thomas, etc. Other shops made similar bars for early Camaros.
Old 01-01-2007, 08:02 AM
Bill,
Those traction bars look tiny compared to the rectangular
type bars on the later Camaro's. How effective were they?
Steve
Old 01-01-2007, 08:05 AM
ss427copo's Avatar
ss427copo ss427copo is offline
Here's my Day2. Has 4 degree wedges from old school rear set ups. Hey BWAG.....you probably did this to the Camaro...any input?
Jeff x2.....HAPPY NEW YEAR
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 01-01-2007, 08:21 AM
Jeff,
Were exactly is the 4 degree wedge and what was its intended
function? Did that trick actually work?
Steve
