Old 12-23-2006, 07:33 AM
scuncio's Avatar
scuncio scuncio is offline
Default Aluminum Wheel Repair
Hi all, I finally found a set of 15" International Dragmasters but one has three cracks on the inside of the hub. I found them after removing the center cap - they are through the thickness of the hub extrusion but do not seem to penetrate the flange area where it's bolted to the car. I think a good TIG job could fix it. Can anyone recommend someone (preferably in Michigan) to do this type of work? Thanks, Tony
Old 12-23-2006, 02:45 PM
TDW TDW is offline
Default Re: Aluminum Wheel Repair
Tony...Give me a call and I will put you in touch with someone that should be able to weld it.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
