Old 12-22-2006, 04:19 AM
JRSully JRSully is offline
Default ID'ing 26 pallets of NOS/old parts
Could use a little help here, have a friend that is a very large Parts rebuilder, he got a tip on an old engine rebuilder/parts distributor that has been closed for years that was getting ready to unload all its leftover inventory and he swooped in and bought it all before the info went public, 26 full pallets of NOS and used Chevy, Ford and Pontiac stuff, Blocks, heads etc. and A LOT of parts in original NOS boxes, nothing aftermarket. Could be junk could be a homerun, I am going to help him go through everything to check part numbers etc and would like to put "crib" sheets together to check for the HiPo p/n's etc. I know Morkar.? for Chevy stuff, need help for the Ford and Pontiac part numbers. Thanks in advance SULLY
71 Porsche 911 Targa
Old 12-22-2006, 04:29 AM
Default Re: ID'ing 26 pallets of NOS/old parts
Will somebody pick up that Damn phone!
Old 12-22-2006, 05:25 AM
68 Vert 68 Vert is offline
You have a PM.
Old 12-22-2006, 05:36 AM
I'll give you $10 per pallet..site unseen....
wilma
Old 12-22-2006, 06:02 AM
bav70ss bav70ss is offline
I'll up that! $15 per!
Soon to be ex-friend of Wilmas!
Old 12-22-2006, 06:11 AM
Sully,
It must be prophetic that that was your post #409! IF you see anything "W" motor related, please send me a PM. And if there's any "W" stuff there that you need part number help with, I'll be glad to give you correct answers.
Rebuilders also tend to stock up on generators, starters, water pumps and master cylinders. I'm very interested in any of those type components that might be applicable to "W" motors.
Thanks for the consideration.
Verne
Old 12-22-2006, 07:45 AM
tom406 tom406 is offline
The Ford stuff will have casting/part numbers configured with a letter and a numeral as the first two characters, and this will help you ID when the part was designed/used.
B=1950's
C=1960's
D=1970's
E=1980's
The number next to it will be the year, ie "C7AE-9425-A" is a 1967 dual four intake for medium riser 427's. A 1970 Boss 302 block will have a "D0..." casting number, and so on. (Note: MANY Ford FE blocks have "427" cast into them, including many 352's and 390's, so don't get too excited!) Once you get a handle on what kind of Ford stuff you have and the era its from, I can help you ID stuff or let you know what books to reference.
Good luck!
Old 12-22-2006, 10:05 AM
Sully,
Was this the site you had in mind for the Chevy numbers,
http://www.mortec.com/location.htm?
John.
Old 12-22-2006, 10:31 PM
Yes, thanks for the correction. Will put some info up on the site once we look through the stuff
