Old 12-21-2006, 06:19 PM
SMGCO SMGCO is offline
Default Next generation 454 ci LS motor ?
I've heard from a reliable source that GM will come out with their next generation ( 454 ci ) LS1 based motor by early 2008. It would be in the ZO6 corvette, available soon thereafter in crate form and outdate our LS7 and C5R motors. Sounds logical to me and would be similar to the switch to 454ci like the change from 427 to 454 in 1970.
Attachments - The Supercar Registry 241913-tn_11-3-06044.jpg 241909-tn_11-3-06036.jpg 241907-tn_11-3-06034.jpg 241906-tn_11-3-06031.jpg
Old 12-21-2006, 06:27 PM
Default Re: Next generation 454 ci LS motor ?
I think they are testing the LS9 now. Beastly I heard.
Old 12-21-2006, 07:43 PM
I saw a video on SteetFire.net that showed a 1969 Camaro built by GM Performance for Reggie Jackson. It had a new GM crate motor; a small block 454 based on the LS platform but it was called the "LSX".
Old 12-25-2006, 05:18 PM
Thanks Stuart. Your description of " Beastly " is basically what heard and more.
1996Z15 the LX is the name of the block that will be available from GMPP. It will go 454 ci with without any additional clearancing for the crank. Per Stuart the complete motor will be the LS9 a 454 ci LS1 based motor. The LS9 like the LS7 will be available in crate form from GMPP. Going to be in the ZO6 and maybe available in the Camaro.
No doubt this will move the bar up another notch or two.
Old 12-25-2006, 06:54 PM
Here is a spec sheet for the LSX block....no charge for my head shadow.
Old 12-25-2006, 06:56 PM
Here is the block
Old 12-25-2006, 06:59 PM
bottom end
Old 12-25-2006, 07:00 PM
here is the engine in Reggie's Camaro
Old 12-25-2006, 07:05 PM
Here is the engine to look out for . This was in the GM booth at SEMA without much fanfare. It was under the hood of a Denali. This is a LS engine with a Supercharger. I would look for a version of this in the next badass Vette etc. It does't take up much space. A couple aftermarket blower manufacturers were spotted staring at it with huge eyeballs... "uh oh"
Old 12-25-2006, 07:09 PM
bottom end
Can you say bulletproof?
